ADV7511 SD register settings
Question asked by Varun on Mar 8, 2012
Latest reply on Mar 27, 2012 by GuenterL
I have HD video working on my ADV7511 with the following register settings, but I am not getting video out when my source is set to 480i/525i. Can anyone confirm that the following register settings are sufficient to pass SD video or are there additional registers that need to be set for SD? My source outputs a 20 bit 422 YCrCb signal, formatted according to style 3 in the adv7511 datasheet.
72 01 00 ; Set N Value(6144)
72 02 18 ; Set N Value(6144)
72 03 00 ; Set N Value(6144)
72 15 21 ; Input 422  YCrCb with Separate Syncs, 48kHz audio
72 16 60 ; Output format 422, 20-bit input, style 3
72 18 46 ; CSC disabled
72 40 80 ; General Control packet enable
72 41 10 ; Power down control
72 48 08 ; Data right justified
72 49 00 ; No truncation
72 4C 06 ; 12 bit Output
72 55 20 ; Set YCrCb 422 in AVinfo Frame
72 56 08 ; Set active format Aspect
72 96 20 ; HPD Interrupt clear
72 98 03 ; ADI Recommended Write
72 99 02 ; ADI Recommended Write
72 9C 30 ; PLL Filter R1 Value
72 9D 61 ; Set clock divide
72 A2 A4 ; ADI Recommended Write
72 A3 A4 ; ADI Recommended Write
72 A5 04 ; ADI Recommended Write
72 AB 40 ; ADI Recommended Write
72 AF 16 ; Set HDMI Mode
72 BA 60 ; No clock delay
72 D1 FF ; ADI Recommended Write
72 DE D8 ; ADI Recommended Write
72 E4 60 ; VCO_Swing_Reference_Voltage
72 FA 7D ; Nbr of times to search for good phase
Varun
