Unable to mount root FS
Question asked by halm on Mar 6, 2012
Latest reply on Mar 7, 2012 by halm
This seems to be a common enough issue that it appears in the FAQ, but I haven't found anything there that helps.
I've inherited a project: uClinux ported to our blackfin board.  I can build, load (flash) and run fine.  However we want to add 2 more partitions to our flash.
In our board file there is this:
static struct mtd_partition cm_partitions[] = {
                .name   = "bootloader(nor)",
                .size   = 0x40000,
                .offset = 0,
                .name   = "uclinux kernel(nor)",
                .size   = 0x180000,
                .offset = MTDPART_OFS_APPEND,
                .name   = "file system(nor)",
                .size   = MTDPART_SIZ_FULL,
I've inserted 2 more partitions to this array just before the final "MTDPART_SIZ_FULL" entry:
                .name   = "uclinux mini kernel (nor)",
                .size   = 0x180000,
                .name   = "mini-linux filesystem",
                .size   = 0x180000,
At boot time I get the "unable to mount root FS" message.
RedBoot partition parsing not available
gpio-addr-flash: Using board partition definition
Creating 5 MTD partitions on "gpio-addr-flash":
0x000000000000-0x000000040000 : "bootloader(nor)"
0x000000040000-0x0000001c0000 : "uclinux kernel(nor)"
0x0000001c0000-0x000000340000 : "uclinux mini kernel(nor)"
0x000000340000-0x0000004c0000 : "mini-linux filesystem"
0x0000004c0000-0x000002000000 : "file system(nor)"
bfin_mii_bus: probed
bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1, mdc_
clk=2500000Hz(mdc_div=19)@sclk=100MHz)
bfin_mac bfin_mac.0: eth0: Blackfin on-chip Ethernet MAC driver, Version 1.1
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
i2c /dev entries driver
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
TCP cubic registered
rtc-bfin rtc-bfin: setting system clock to 1970-01-01 00:00:00 UTC (0)
dma_alloc_init: dma_page @ 0x011aa000 - 256 pages at 0x01f00000
List of all partitions:
1f00             256 mtdblock0  (driver?)
1f01            1536 mtdblock1  (driver?)
1f02            1536 mtdblock2  (driver?)
1f03            1536 mtdblock3  (driver?)
1f04           27904 mtdblock4  (driver?)
No filesystem could mount root, tried:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)
The boot is seeing my new partitions.  If I remove my 2 new partitions then this works again, and so I'm convinced that jffs2 is there.  At this point I still want to boot from the original "uclinux" partition, so I haven't changed anything in my boot commands.
I have no idea what else could be wrong or where to look.  Hoping someone can point me in the right direction.
