UBIFS on 2011R1-RC5 isn't working from upgrade on 2010RC1-RC5
Question asked by MarkBishop on Feb 22, 2012
Latest reply on May 18, 2012 by MarkBishop
On 2010RC1-RC5 I have a working ubi partition on NAND, but when I upgrade to 2011RC1-RC5 it breaks.
Steps used to create the image:
./mkfs.ubifs -r filesystem/ -m 2048 -e 129024 -c 1012 -o ubifs.img
./ubinize -o ubi.img -m 2048 -p 128KiB -s 512 ubinize.cfg
Contents of ubinize.cfg:
mark@linux-hez9:~/UBI> cat ubinize.cfg
[ubifs]
mode=ubi
image=ubifs.img
vol_id=0
vol_size=100MiB
vol_type=dynamic
vol_name=cooper
vol_flags=autoresize
vol_alignment=1
On the target (works on 2010R1-RC3):
root:/> ubiattach /dev/ubi_ctrl -m 3
UBI: attaching mtd3 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    129024 bytes
UBI: smallest flash I/O unit:    2048
UBI: sub-page size:              512
UBI: VID header offset:          512 (aligned 512)
UBI: data offset:                2048
UBI: attached mtd3 to ubi0
UBI: MTD device name:            "file system(ubifs)"
UBI: MTD device size:            126 MiB
UBI: number of good PEBs:        1012
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 1012
UBI: number of PEBs reserved for bad PEB handling: 10
UBI: max/mean erase counter: 1/0
UBI: image sequence number: 0
UBI: background thread "ubi_bgt0d" started, PID 48
UBI device number 0, total 1012 LEBs (130572288 bytes, 124.5 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
root:/> mount -t ubifs ubi0 /mnt/ubitest/
On 2011R1-RC5:
UBI: max. sequence number:       2
UBI: number of good PEBs:        996
UBI: number of bad PEBs:         16
UBI: number of corrupted PEBs:   0
UBI: number of user volumes:     0
UBI: available PEBs:             983
UBI: total number of reserved PEBs: 13
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1/1
UBI: image sequence number:  1446951812
UBI: background thread "ubi_bgt0d" started, PID 305
UBIFS error (pid 313): ubifs_mount: cannot open "ubi0", error -19
mount: mounting ubi0 on /mnt/ failed: No such device
Also tried:
root:/> mount -t ubifs ubi0:cooper /mnt/ubitest/
root:/> mount -t ubifs ubi0!cooper /mnt/ubitest/
All with the same error code.  "UBI: number of user volumes:  0" is what I am seeing different.
For 2010R1-RC5:
I utilized the 'ubinize' located: /usr/sbin/ubinize as that I couldn't find one in the distribution.
and 'mkfs.ubifs' located: ./user/mtd-utils/build-606f38a2221648ca5c5fa292c9f71d2ddd59fa66-host/mkfs.ubifs
For 2011R1-RC5:
I utilized the 'ubinize' located: ./user/mtd-utils/build-36d8de81049c9c908740b690c664b5bd3703ccd6-host/ubi-utils
and 'mkfs.ubifs' located: ./user/mtd-utils/build-36d8de81049c9c908740b690c664b5bd3703ccd6-host/mkfs.ubifs
I also tried my local copy of ubinize for 2011R1-RC5 and it didn't work as well.
I followed the setup here: http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:ubifs
And I am trying to load a pre-made image (from filesystem), and not create a blank image.
