compiling musescore for uCLinux with QT and cmake
Question asked by willrobot on Feb 22, 2012
Latest reply on May 24, 2012 by Aaronwu
I've try few things but I still have this erroe when trying to cmake for blackfin:
CMake Error at CMakeLists.txt:116 (message):
  Fatal error: QT (version >= 4.5.0) required.  Cmake tries to detect QT4 by
  searching for 'qmake' in your PATH.If you have QT4 installed, make sure
  qmake is found in your PATH.  If you compiled QT4 yourself make sure your
  new qmake ist found _first_ in your PATH.
I'm trying to compile the source of musescore 0.9.5 to keep it compatible with the existing version of QT in uClinux options
What I did is to compile the uClinux kernel with QT lib so I can have the suitable embedded QT.
then I modified the Makefile of musescore to build with uclinux compilers. I've try different things so I show here the latest trial:
bfin:
        mkdir build;
        mkdir install;                               \
        cd build;
        cmake -DCMAKE_TOOLCHAIN_FILE=bfin.cmake -DCMAKE_VERBOSE_MAKEFILE=TRUE -\
DQT_QMAKE_EXECUTABLE=/home/william/Development_new/Music_Recognition/code/uCLin\
ux/rev2011R1/uclinux-dist/lib/qt-embedded/build-qt-embedded-linux-opensource-sr\
c-4.5.1/bin         -libdir=/home/william/Development_new/Music_Recognition/cod\
e/uCLinux/rev2011R1/uclinux-dist/lib/qt-embedded/build-qt-embedded-linux-openso\
urce-src-4.5.1/lib    \
              -DCMAKE_INSTALL_PREFIX="${PREFIX}" \
               mscore;
in the CMakeLists.txt I did add:
link_directories(/home/william/Development_new/Music_Recognition/code/uCLinux/r\
ev2011R1/uclinux-dist/lib/qt-embedded/build-qt-embedded-linux-opensource-src-4.\
5.1/bin)
SET(CMAKE_MODULE_PATH /home/william/Development_new/Music_Recognition/code/uCLi\
nux/rev2011R1/uclinux-dist/lib/qt-embedded/build-qt-embedded-linux-opensource-s\
rc-4.5.1/bin)
SET(CMAKE_PREFIX_PATH /home/william/Development_new/Music_Recognition/code/uCLi\
rc-4.5.1/bin)
SET(QT_QMAKE_EXECUTABLE /home/william/Development_new/Music_Recognition/code/uC\
Linux/rev2011R1/uclinux-dist/lib/qt-embedded/build-qt-embedded-linux-opensource\
-src-4.5.1/bin)
my bfin.cmake look like that:
# this one is important
SET(CMAKE_SYSTEM_NAME Linux)
#this one not so much
SET(CMAKE_SYSTEM_VERSION 1)
SET (BFIN "/opt/uClinux/bfin-uclinux")
# specify the cross compiler
SET(CMAKE_C_COMPILER ${BFIN}/bin/bfin-uclinux-gcc)
SET(CMAKE_CXX_COMPILER   ${BFIN}/bin/bfin-uclinux-g++)
SET(CMAKE_LINKER     ${BFIN}/bin/bfin-uclinux-ld)
#/opt/uClinux/bfin-uclinux/bfin-uclinux/runtime/usr/lib
LINK_DIRECTORIES("${BFIN}/usr/lib")
SET(CMAKE_FIND_ROOT_PATH
  /opt/uClinux/bfin-linux-uclibc
  /opt/uClinux/bfin-linux-uclibc/bfin-linux-uclibc/runtime)
# search for programs in the build host directories
SET(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
# for libraries and headers in the target directories
SET(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
SET(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
Thanks in advance for the help,
William
