U-BOOT >bfin prompt 'u-boot-bf526-ezbrd-uart-2011R1-RC5'
Question asked by nick0mg on Feb 16, 2012
Latest reply on Feb 19, 2012 by Aaronwu
After loading the latest u-boot release, u-boot-bf526-ezbrd-uart-2011R1-RC5 on BF526-EZBRD I don't get the >bfin prompt. I'm using the documented commands, is there a step I am missing? Output below.
SW1 is set to 8, the UART loopback jumper is removed and I'm using an USB to RS232 serial cable.
I also have a couple of questions if anyone can help.
-After U-Boot is loaded and the board reset, should U-BOOT respond to a Kermit connection with the bfin prompt?
-I want to boot out of SPI flash, after loading the u-boot SPI image is the UART enabled for TFTP kernal download?
sudo ./bfin-uclinux-ldr -l /home/nick/auto/2011R1-tar/u-boot-bf526-ezbrd-2011R1-RC5/u-boot-bf526-ezbrd-uart-2011R1-RC5.ldr /dev/ttyUSB0 && kermit -l /dev/ttyUSB0 -b 57600 -C connect
nick@nick-uCLinux:/$ sudo ./bfin-uclinux-ldr -l /home/nick/auto/2011R1-tar/u-boot-bf526-ezbrd-2011R1-RC5/u-boot-bf526-ezbrd-uart-2011R1-RC5.ldr /dev/ttyUSB0 && kermit -l /dev/ttyUSB0 -b 57600 -C connect
sudo: ./bfin-uclinux-ldr: command not found
nick@nick-uCLinux:/$ bfin-uclinux-ldr -l /home/nick/auto/2011R1-tar/u-boot-bf526-ezbrd-2011R1-RC5/u-boot-bf526-ezbrd-uart-2011R1-RC5.ldr /dev/ttyUSB0 && kermit -l /dev/ttyUSB0 -b 57600 -C connect
Loading LDR /home/nick/auto/2011R1-tar/u-boot-bf526-ezbrd-2011R1-RC5/u-boot-bf526-ezbrd-uart-2011R1-RC5.ldr ... OK!
Removing stale lock '//var/lock/LCK..ttyUSB0'
Opening /dev/ttyUSB0 ... OK!
Configuring terminal I/O ... OK!
Trying to send autobaud ... OK!
Trying to read autobaud ... OK!
Checking autobaud ... OK!
Autobaud result: 115200bps 36.864mhz (header:0xBF DLL:0x14 DLH:0x00 fin:0x00)
Sending blocks of DXE 1 ... [21/21] (100%)[board said: �]
[board said: ���怘�ff� �����`  x]
[board said:  �  `����  ���� �f��  �`fx  ��  ]
[board said: ��� x��x]
[board said: f x]
[board said: 怘� �� �� x� �]
[board said:  �� x]
[board said:   ~�  �` ~]
[board said: �����x������f�� �����f ���� �x�]
[board said: �怘�  ��� ���~]
[board said:  fx�   ]
[board said: �� ~ff��    �  ��f��� f]
[board said:    ` � f� f���]
[board said: x]
[board said:  � �� �� �` � f� f��]
[board said: �������]
[board said: ����f���~  xf�x f~��` ����xf� ������f]
[board said: ��`f���怘������    ��fx f�  �怘���f ~�]
[board said:    ��fx f�  �怘�f�����~]
[board said: 怘���~ ` �~]
OK!
You may want to run minicom or kermit now
Quick tip: run 'ldr <ldr> <devspec> && minicom'
Connecting to /dev/ttyUSB0, speed 57600
Escape character: Ctrl-\ (ASCII 28, FS): enabled
Type the escape character followed by C to get back,
or followed by ? to see other options.
x � �� � ����`fx  ~ ~����f��f ~�� ~�� x`��fx ��  x�xx      x  ~  ���
