spi-SD write error
Question asked by icyrat on Feb 13, 2012
Latest reply on Feb 14, 2012 by Aaronwu
Hello everybody!
I have an error in copying large files.
Here is my system information:
Hardware: bf561(0.5)
Software: Linux version 2.6.34.7-ADI-2010R1 (qianxin@azure) (gcc version 4.3.5 (ADI-2010R1-RC4) )
My operation is:
root:/mnt/azure_demo> cp novo novo1    (novo file size is 10M)
cp: write error: Input/output error
The dmesg Information is:
root:/> dmesg
Linux version 2.6.34.7-ADI-2010R1 (qianxin@azure) (gcc version 4.3.5 (ADI-2010R1-RC4) ) #1473 Wed Jan 4 11:25:45 CST 2012
register early platform devices
Board Memory: 128MB
Kernel Managed Memory: 74MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00100000-0x00214520
  rodata    = 0x00214520-0x0026d0c8
  bss       = 0x0026e000-0x0027e2c8
  data      = 0x0027e2c8-0x00290000
    stack   = 0x0028e000-0x00290000
  init      = 0x00290000-0x004a0000
  available = 0x004a0000-0x04800000
  DMA Zone  = 0x04800000-0x04a00000
Hardware Trace Active and Enabled
Boot Mode: 2
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF561 Rev 0.5
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 528 MHz core clock and 132 MHz System Clock
boot memmap: 00000000004a0000 - 0000000004800000 (usable)
On node 0 totalpages: 18432
free_area_init_node: node 0, pgdat 0028ba88, node_mem_map 004a2000
  DMA zone: 144 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 18288 pages, LIFO batch:0
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
  L2 SRAM        : uncacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
  L2 SRAM        : uncacheable in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 18288
Kernel command line: root=/dev/mtdblock0 rw mem=74M max_mem=128M$# clkin_hz=33000000 console= quiet lpj=2097152
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Kernel managed physical pages: 18432
Memory available: 68120k/75776k RAM, (2112k init code, 1105k kernel code, 495k data, 2048k dma, 1896k reserved)
Hierarchical RCU implementation.
NR_IRQS:153
Configuring Blackfin Priority Driven Interrupts
Calibrating delay loop (skipped) preset value.. 1048.57 BogoMIPS (lpj=2097152)
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 16 KB (5 KB free)
Blackfin L2 SRAM: 128 KB (128 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
bio: create slab <bio-0> at 0
bfin-spi bfin-spi.0: chipselect 5 already in use
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs_base@ffc00500, dma channel@16
i2c-gpio i2c-gpio.0: using pins 45 (SDA) and 26 (SCL)
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
msgmni has been set to 133
io scheduler noop registered (default)
dma_alloc_init: dma_page @ 0x0216d000 - 512 pages at 0x04800000
bfin-lq035q1 bfin-lq035q1: 480x272 16-bit RGB FrameBuffer initialized
brd: module loaded
net2272: PLX NET2272 USB Peripheral Controller
net2272: irq 103, mapped mem 28000000, chip rev 0011
net2272: running in 16-bit, no byte swap local bus mode
net2272: version: 2005 Sept 8
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 5e:0d:61:5d:ad:9a
usb0: HOST MAC 0a:ed:5f:8e:ef:b4
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
bfin-gpio: GPIO 0 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 1 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 10 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 11 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 2 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 3 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 4 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 8 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 9 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 12 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 13 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
bfin-gpio: GPIO 24 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
input: gpio-keys as /devices/platform/gpio-keys.0/input/input0
i2c /dev entries driver
mmc_spi spi0.7: ASSUMING 3.2-3.4 V slot power
mmc_spi spi0.7: SD/MMC host mmc0, no DMA, no WP, no poweroff
TCP cubic registered
Warning: unable to open an initial console.
Freeing unused kernel memory: 2112k freed
mmc_spi spi0.7: can't change chip-select polarity
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SD card on SPI
mmcblk0: mmc0:0000 SA02G 1.83 GiB
mmcblk0:
g_ether gadget: high speed config #2: RNDIS
dma rx:12 tx:13, err irq:13, regs:ffc00800
qian:No device for DAI tlv320aic23
qian:soc_probe!
AIC23 Audio Codec 0.1
asoc: tlv320aic23 <-> bf5xx-i2s mapping ok
mmcblk0: error -38 sending read/write command, response 0x4, card status 0x0
end_request: I/O error, dev mmcblk0, sector 1348
Buffer I/O error on device mmcblk0, logical block 1348
lost page write due to I/O error on mmcblk0
end_request: I/O error, dev mmcblk0, sector 1349
Buffer I/O error on device mmcblk0, logical block 1349
end_request: I/O error, dev mmcblk0, sector 1350
Buffer I/O error on device mmcblk0, logical block 1350
end_request: I/O error, dev mmcblk0, sector 1351
Buffer I/O error on device mmcblk0, logical block 1351
end_request: I/O error, dev mmcblk0, sector 1352
Buffer I/O error on device mmcblk0, logical block 1352
end_request: I/O error, dev mmcblk0, sector 1353
Buffer I/O error on device mmcblk0, logical block 1353
end_request: I/O error, dev mmcblk0, sector 1354
Buffer I/O error on device mmcblk0, logical block 1354
end_request: I/O error, dev mmcblk0, sector 1355
Buffer I/O error on device mmcblk0, logical block 1355
end_request: I/O error, dev mmcblk0, sector 1356
Buffer I/O error on device mmcblk0, logical block 1356
end_request: I/O error, dev mmcblk0, sector 1357
Buffer I/O error on device mmcblk0, logical block 1357
end_request: I/O error, dev mmcblk0, sector 1358
end_request: I/O error, dev mmcblk0, sector 1359
end_request: I/O error, dev mmcblk0, sector 1360
end_request: I/O error, dev mmcblk0, sector 1361
end_request: I/O error, dev mmcblk0, sector 1362
end_request: I/O error, dev mmcblk0, sector 1363
end_request: I/O error, dev mmcblk0, sector 1364
end_request: I/O error, dev mmcblk0, sector 1365
end_request: I/O error, dev mmcblk0, sector 1366
end_request: I/O error, dev mmcblk0, sector 1367
end_request: I/O error, dev mmcblk0, sector 1368
end_request: I/O error, dev mmcblk0, sector 1369
end_request: I/O error, dev mmcblk0, sector 1370
end_request: I/O error, dev mmcblk0, sector 1371
end_request: I/O error, dev mmcblk0, sector 1372
end_request: I/O error, dev mmcblk0, sector 1373
end_request: I/O error, dev mmcblk0, sector 1374
end_request: I/O error, dev mmcblk0, sector 1375
end_request: I/O error, dev mmcblk0, sector 1376
end_request: I/O error, dev mmcblk0, sector 1377
end_request: I/O error, dev mmcblk0, sector 1378
end_request: I/O error, dev mmcblk0, sector 1379
end_request: I/O error, dev mmcblk0, sector 1380
end_request: I/O error, dev mmcblk0, sector 1381
end_request: I/O error, dev mmcblk0, sector 1382
end_request: I/O error, dev mmcblk0, sector 5105
end_request: I/O error, dev mmcblk0, sector 5106
end_request: I/O error, dev mmcblk0, sector 5107
end_request: I/O error, dev mmcblk0, sector 5108
end_request: I/O error, dev mmcblk0, sector 5109
end_request: I/O error, dev mmcblk0, sector 5110
end_request: I/O error, dev mmcblk0, sector 5111
end_request: I/O error, dev mmcblk0, sector 5112
end_request: I/O error, dev mmcblk0, sector 5113
end_request: I/O error, dev mmcblk0, sector 5114
end_request: I/O error, dev mmcblk0, sector 5115
end_request: I/O error, dev mmcblk0, sector 5116
end_request: I/O error, dev mmcblk0, sector 5117
end_request: I/O error, dev mmcblk0, sector 5118
end_request: I/O error, dev mmcblk0, sector 5119
end_request: I/O error, dev mmcblk0, sector 5120
end_request: I/O error, dev mmcblk0, sector 5121
end_request: I/O error, dev mmcblk0, sector 5122
end_request: I/O error, dev mmcblk0, sector 5123
end_request: I/O error, dev mmcblk0, sector 5124
end_request: I/O error, dev mmcblk0, sector 5125
end_request: I/O error, dev mmcblk0, sector 5126
end_request: I/O error, dev mmcblk0, sector 5127
end_request: I/O error, dev mmcblk0, sector 5128
end_request: I/O error, dev mmcblk0, sector 5129
end_request: I/O error, dev mmcblk0, sector 5130
end_request: I/O error, dev mmcblk0, sector 5131
end_request: I/O error, dev mmcblk0, sector 5132
end_request: I/O error, dev mmcblk0, sector 5133
end_request: I/O error, dev mmcblk0, sector 5134
end_request: I/O error, dev mmcblk0, sector 5135
end_request: I/O error, dev mmcblk0, sector 5136
end_request: I/O error, dev mmcblk0, sector 5137
end_request: I/O error, dev mmcblk0, sector 5138
end_request: I/O error, dev mmcblk0, sector 5139
end_request: I/O error, dev mmcblk0, sector 9246
end_request: I/O error, dev mmcblk0, sector 1369712
end_request: I/O error, dev mmcblk0, sector 1369720
end_request: I/O error, dev mmcblk0, sector 1369728
end_request: I/O error, dev mmcblk0, sector 1369736
end_request: I/O error, dev mmcblk0, sector 1369744
end_request: I/O error, dev mmcblk0, sector 1369752
end_request: I/O error, dev mmcblk0, sector 1369760
end_request: I/O error, dev mmcblk0, sector 1369768
end_request: I/O error, dev mmcblk0, sector 1369776
end_request: I/O error, dev mmcblk0, sector 1369784
end_request: I/O error, dev mmcblk0, sector 1369792
end_request: I/O error, dev mmcblk0, sector 1369800
end_request: I/O error, dev mmcblk0, sector 1369808
end_request: I/O error, dev mmcblk0, sector 1369816
end_request: I/O error, dev mmcblk0, sector 1369824
end_request: I/O error, dev mmcblk0, sector 1369832
end_request: I/O error, dev mmcblk0, sector 1369874
end_request: I/O error, dev mmcblk0, sector 1369880
end_request: I/O error, dev mmcblk0, sector 1369888
end_request: I/O error, dev mmcblk0, sector 1369896
end_request: I/O error, dev mmcblk0, sector 1369904
end_request: I/O error, dev mmcblk0, sector 1369912
end_request: I/O error, dev mmcblk0, sector 1369920
end_request: I/O error, dev mmcblk0, sector 1369928
end_request: I/O error, dev mmcblk0, sector 1369936
end_request: I/O error, dev mmcblk0, sector 1369944
end_request: I/O error, dev mmcblk0, sector 1369952
end_request: I/O error, dev mmcblk0, sector 1369960
FAT: Filesystem error (dev mmcblk0)
    fat_get_cluster: invalid cluster chain (i_pos 147938)
    File system has been set read-only
root:/>
thanks!
