bf548-ezkit: No soundcards found
Question asked by rubick64 on Feb 10, 2012
Latest reply on Jun 14, 2012 by Aaronwu
I have uClinux 2011R1-RC3 and it can't find AD1980 soundcard located on the board. It was working with previous version (i think 2008, don't remeber). I am using default settings. What should i do to make it work? thank you.
Starting Kernel at = 002cfe68
Linux version 3.0.8-ADI-2011R1 (ondra@arch) (gcc version 4.3.5 (ADI-2011R1-RC4) ) #10 Tue Jan 31 22:05:34 CET 2012
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart1] enabled
early printk enabled on early_BFuart1
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x001e7088
  rodata    = 0x001e7088-0x0028cff8
  bss       = 0x0028d000-0x002a19e4
  data      = 0x002a19e4-0x002c6000
    stack   = 0x002c4000-0x002c6000
  init      = 0x002c6000-0x00acc000
  available = 0x00acc000-0x03e00000
  DMA Zone  = 0x03e00000-0x04000000
Hardware Trace active and enabled
Boot Mode: 3
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF548 Rev 0.2
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 525 MHz core clock and 131 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
  L2 SRAM        : uncacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
  L2 SRAM        : uncacheable in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 15748
Kernel command line: root=/dev/sda rw clkin_hz=25000000 earlyprintk=serial,uart1,57600 console=tty0 console=ttyBF1,57600
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 51824k/65536k RAM, (8216k init code, 1944k kernel code, 892k data, 2048k dma, 612k reserved)
NR_IRQS:295
Configuring Blackfin Priority Driven Interrupts
bfin-rtc: invalid date; resetting
Console: colour dummy device 80x25
console [tty0] enabled
console [ttyBF1] enabled, bootconsole disabled
Calibrating delay loop... 1044.48 BogoMIPS (lpj=2088960)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (41 KB free)
Blackfin L2 SRAM: 128 KB (128 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
spi spi0.2: Warning: SPI CPHA not set: Slave Select not under software control!
See Documentation/blackfin/bfin-spi-notes.txt
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@4
bfin-spi bfin-spi.1: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc02300, dma channel@5
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc00700
i2c-bfin-twi i2c-bfin-twi.1: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc02200
Advanced Linux Sound Architecture Driver Version 1.0.24.
musb-hdrc: version 6.0, musb-dma, host
musb-hdrc musb-hdrc: MUSB HDRC host driver
musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc: USB Host mode controller at ffc03c00 using DMA, IRQ 82
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
debug-mmrs: setting up Blackfin MMR debugfs
msgmni has been set to 101
io scheduler noop registered (default)
bf54x-lq043: FrameBuffer initializing...
dma_alloc_init: dma_page @ 0x02ae4000 - 512 pages at 0x03e00000
Console: switching to colour frame buffer device 80x24
bfin-uart: Blackfin serial driver
bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 48) is a BFIN-UART
bfin-otp: initialized
brd: module loaded
register bfin atapi driver
scsi0 : pata-bf54x
ata1: PATA max UDMA/66 irq 68
physmap platform flash device: 02000000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00881e
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
Using physmap partition information
Creating 5 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000080000 : "bootloader(nor)"
0x000000080000-0x000000480000 : "linux kernel(nor)"
0x000000480000-0x000000fe0000 : "file system(nor)"
0x000000fe0000-0x000000ff8000 : "config(nor)"
0x000000ff8000-0x000001000000 : "u-boot env(nor)"
m25p80 spi0.1: m25p16 (2048 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000080000 : "bootloader(spi)"
0x000000080000-0x000000200000 : "linux kernel(spi)"
BF5xx on-chip NAND FLash Controller Driver, Version 1.2 (c) 2007 Analog Devices, Inc.
bf5xx-nand bf5xx-nand.0: data_width=8, wr_dly=3, rd_dly=3
NAND device: Manufacturer ID: 0x20, Chip ID: 0xda (ST Micro NAND 256MiB 3,3V 8-bit)
Creating 3 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x000000000000-0x000000080000 : "bootloader(nand)"
0x000000080000-0x000000480000 : "linux kernel(nand)"
0x000000480000-0x000010000000 : "file system(nand)"
smsc911x: Driver version 2008-10-21
ata1.00: ATA-7: FUJITSU MHW2040AT, 0000000B, max UDMA/100
ata1.00: 78140160 sectors, multi 16: LBA
ata1.00: configured for UDMA/66
blk_queue_max_segments: set to minimum 1
scsi 0:0:0:0: Direct-Access     ATA      FUJITSU MHW2040A 0000 PQ: 0 ANSI: 5
smsc911x-mdio: probed
smsc911x smsc911x.0: eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1)
smsc911x smsc911x.0: eth0: MAC Address: 00:e0:22:fe:be:15
sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
input: bf54x-keys as /devices/platform/bf54x-keys/input/input0
sda: unknown partition table
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
i2c /dev entries driver
sd 0:0:0:0: [sda] Attached SCSI disk
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
bfin-ac97 bfin-ac97.0: dma rx:0 tx:1, err irq:10, regs:ffc00800
ALSA device list:
  No soundcards found.
TCP cubic registered
rtc-bfin rtc-bfin: setting system clock to 1970-01-02 01:27:38 UTC (91658)
Freeing unused kernel memory: 8216k freed
                           _____________________________________
        a8888b.           / Welcome to the uClinux distribution \
       d888888b.         /       _     _                         \
       8P"YP"Y88        /       | |   |_|            __  __ (TM)  |
       8|o||o|88  _____/        | |    _ ____  _   _ \ \/ /       |
       8'    .88       \        | |   | |  _ \| | | | \  /        |
       8`._.' Y8.       \       | |__ | | | | | |_| | /  \        |
      d/      `8b.       \      \____||_|_| |_|\____|/_/\_\       |
     dP   .    Y8b.       \   For embedded processors including   |
    d8:'  "  `::88b        \    the Analog Devices Blackfin      /
   d8"         'Y88b        \___________________________________/
  :8P    '      :888
   8a.   :     _a88P         For further information, check out:
._/"Yaa_:   .| 88P|            - http://blackfin.uclinux.org/
\    YP"    `| 8P  `.          - http://docs.blackfin.uclinux.org/
/     \.___.d|    .'           - http://www.uclinux.org/
`--..__)8888P`._.'  jgs/a:f    - http://www.analog.com/blackfin
Have a lot of fun...
BusyBox v1.18.4 (2012-01-31 21:34:54 CET) hush - the humble shell
root:/>
