Problem with EZKIT BF548 image
Question asked by TerryXu on Feb 6, 2012
Latest reply on Feb 7, 2012 by Aaronwu
http://blackfin.uclinux.org/gf/download/frsrelease/509/8620/uImage-bf548-ezkit-2010R1-RC
Hello
I used ezkit BF548 REV1.3 and I used the BF548 image from the link showed.
I loaded the para flash u-boot and set the tftp server correctly, then the u-boot reset and get the uimage correctly from host tftp server, but the image has the problem when startup:
Load address: 0x1000000
Loading: T #################################################################
done
Bytes transferred = 5407883 (52848b hex)
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf548-2.6.34.7-ADI-2010R1
   Created:      2010-11-29  10:44:35 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    5407819 Bytes = 5.2 MiB
   Load Address: 00001000
   Entry Point:  002a28b4
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 002a28b4
Linux version 2.6.34.7-ADI-2010R1 (root@eight) (gcc version 4.3.5 (ADI-2010R1-R0
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart1] enabled
early printk enabled on early_BFuart1
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x001b96d0
  rodata    = 0x001b96d0-0x002577e0
  bss       = 0x00258000-0x0026f988
  data      = 0x0026f988-0x00290000
    stack   = 0x0028e000-0x00290000
  init      = 0x00290000-0x00a0b000
  available = 0x00a0b000-0x03e00000
  DMA Zone  = 0x03e00000-0x04000000
Hardware Trace Active and Enabled
Boot Mode: 1
Reset caused by Software reset
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF548 Rev 0.2
Warning: Compiled for Rev 2, but running on Rev 0
Kernel panic - not syncing: Error: you are missing anomaly workarounds for thisv
Hardware Trace:
   0 Target : <0x001b7eb4> { _dump_stack + 0x0 }
     Source : <0x001b7f2e> { _panic + 0x42 } CALL pcrel
   1 Target : <0x001b7f2e> { _panic + 0x42 }
     Source : <0x001b7fb8> { _printk + 0x14 } RTS
   2 Target : <0x001b7fb4> { _printk + 0x10 }
     Source : <0x00010d4e> { _vprintk + 0x16a } RTS
   3 Target : <0x00010d42> { _vprintk + 0x15e }
     Source : <0x00010d34> { _vprintk + 0x150 } IF CC JUMP pcrel
   4 Target : <0x00010d2c> { _vprintk + 0x148 }
     Source : <0x00010e16> { _vprintk + 0x232 } JUMP.S
   5 Target : <0x00010e16> { _vprintk + 0x232 }
     Source : <0x00010966> { _release_console_sem + 0x1be } RTS
   6 Target : <0x0001095e> { _release_console_sem + 0x1b6 }
     Source : <0x00010950> { _release_console_sem + 0x1a8 } IF CC JUMP pcrel
   7 Target : <0x00010940> { _release_console_sem + 0x198 }
     Source : <0x00010932> { _release_console_sem + 0x18a } IF CC JUMP pcrel (B)
   8 Target : <0x0001092a> { _release_console_sem + 0x182 }
     Source : <0x0002327a> { _up + 0x3e } RTS
   9 Target : <0x00023274> { _up + 0x38 }
     Source : <0x00023266> { _up + 0x2a } IF CC JUMP pcrel (BP)
  10 Target : <0x0002323c> { _up + 0x0 }
     Source : <0x00010926> { _release_console_sem + 0x17e } JUMP.L
  11 Target : <0x00010912> { _release_console_sem + 0x16a }
     Source : <0x0001080a> { _release_console_sem + 0x62 } IF CC JUMP pcrel
  12 Target : <0x000107ea> { _release_console_sem + 0x42 }
     Source : <0x0001083c> { _release_console_sem + 0x94 } IF CC JUMP pcrel (BP)
  13 Target : <0x00010832> { _release_console_sem + 0x8a }
     Source : <0x000103ba> { __call_console_drivers + 0x62 } RTS
  14 Target : <0x000103b4> { __call_console_drivers + 0x5c }
     Source : <0x0001038e> { __call_console_drivers + 0x36 } IF CC JUMP pcrel
  15 Target : <0x0001037e> { __call_console_drivers + 0x26 }
     Source : <0x0001036e> { __call_console_drivers + 0x16 } IF !CC JUMP pcrel )
Stack info:
SP: [0x0028ff8c] <0x0028ff8c> /* kernel dynamic memory (maybe user-space) */
Invalid stack pointer
