Runtime error in bf561 COREB when pointing to structure data
Question asked by willrobot on Feb 6, 2012
Latest reply on Mar 14, 2012 by willrobot
Hi, I've a runtime error in several function when it try to access structure data generally pass as a parameter to the function.
the first instance of the problem is:
signed portBASE_TYPE xQueueGenericReceive( xQueueHandle pxQueue, void * const p\
vBuffer, portTickType xTicksToWait, portBASE_TYPE xJustPeeking )
if( pxQueue->uxMessagesWaiting > ( unsigned portBASE_TY\
PE ) 0 )
where pxQueue is a structure:
typedef xQUEUE * xQueueHandle;
with:
typedef struct QueueDefinition
        signed char *pcHead;                            /*< Points to the begin\
ning of the queue storage area. */
    signed char *pcTail;                            /*< Points to the byte \
at the end of the queue storage area.  Once more byte is allocated than necessa\
ry to store the queue items, this is used as a marker. */
        signed char *pcWriteTo;                         /*< Points to the free \
next place in the storage area. */
        signed char *pcReadFrom;
                 /*< Points to the last \
place that a queued item was read from. */
    xList xTasksWaitingToSend;                          /*< List of tas\
ks that are blocked waiting to post onto this queue.  Stored in priority order.\
    xList xTasksWaitingToReceive;               /*< List of tasks that \
are blocked waiting to read from this queue.  Stored in priority order. */
    volatile unsigned portBASE_TYPE uxMessagesWaiting;/*< The number of ite\
ms currently in the queue. */
    unsigned portBASE_TYPE uxLength;            /*< The length of the q\
ueue defined as the number of items it will hold, not the number of bytes. */
    unsigned portBASE_TYPE uxItemSize;          /*< The size of each it\
ems that the queue will hold. */
    signed portBASE_TYPE xRxLock;               /*< Stores the number o\
f items received from the queue (removed from the queue) while the queue was lo\
cked.  Set to queueUNLOCKED when the queue is not locked. */
    signed portBASE_TYPE xTxLock;               /*< Stores the number o\
f items transmitted to the queue (added to the queue)
while the queue was locke\
} xQUEUE;
the runtime error is:
COREB: start xQueueGenericReceive
COREB: execption 24 addr 3c00384
COREB: coreb dump stack
COREB: found fp: ff700900
COREB:  call frame 0 -12 feb055e2
COREB:  call frame 0 -11 00000000
COREB:  call frame 0 -9 00000000
COREB:  call frame 0 -8 ff7008d0
Similarly, I've the same problem with the following function:
void vListRemove( xListItem *pxItemToRemove )
xList * pxList;
   pxItemToRemove->pxNext->pxPrevious = pxItemToRemove->pxPrevious;
        pxItemToRemove->pxPrevious->pxNext = pxItemToRemove->pxNext;
where pxItemToRemove->pxPrevious can be read but not pxItemToRemove->pxNext->pxPrevious
it structure is:
struct xLIST_ITEM
     portTickType xItemValue;                                /*< The value b\
eing listed.  In most cases this is used to sort the list in descending order. \
        volatile struct xLIST_ITEM * pxNext;    /*< Pointer to the next xListIt\
em in the list. */
        volatile struct xLIST_ITEM * pxPrevious;/*< Pointer to the previous xLi\
stItem in the list. */
        void * pvOwner;                                                 /*< Poi\
nter to the object (normally a TCB) that contains the list item.  There is ther\
efore a two way link between the object containing the list item and the list i\
tem itself. */
        void * pvContainer;                                             /*< Poi\
nter to the list in which this list item is placed (if any). */
typedef struct xLIST_ITEM xListItem;            /* For some reason lint wants t\
his as two separate definitions. */
COREB: got to vTaskDelete
COREB: pxTCB GLI prev: a5a5a5a5
COREB: sent to list: 3d02004
COREB: list_rem px prev: a5a5a5a5
COREB: execption 24 addr 3c05444
COREB: found fp: ff7008fc
COREB:  call frame 0 -8 ff7008cc
COREB:  call frame 0 -7 ff700ff4
Thank you in advance.
William
