complex_float (TS201)
Question asked by Griff241 on Feb 2, 2012
Latest reply on Feb 14, 2012 by Griff241
I am using the TS201 and wanted to extract only the real values from a complex_float.  complex_float is defined as:
typedef struct
    float re;       /*{ Real      }*/
    float im;       /*{ Imaginary }*/
} _complex_float;
In my program, I have the following variables defined:
complex_float input[8192];    //Input data into ifft
complex_float temp[8192];    //Working buffer
complex_float output[8192];    //Output data
static complex_float twidtab[8192*3/4];  //Twiddle Table
The program fills input with data and populates the twiddle table.  Next, I perform an ifft:
ifft (input, temp, output, twidtab, 1, 8192);
The ifft returns the the result to output.  I am only interested in the real portion of the output.  What is the best way to extract only the real portion?  I can obviously do it with a loop but that is not very efficient. Example:
float real_data[8192];
for(i=0; i< 8192;i++)
real_data[i] = output[i].re;
Is there a better way to do this like a built in function that I am missing?  Thanks!
