ADuC7060 timer capture accuracy?
Question asked by tcachat on Jan 25, 2012
Latest reply on Mar 13, 2012 by tcachat
Dear all,
We use an ADuC7060 to measure an external frequency in the range 0.1Hz to 2kHz. The capture interrupt do the job, but I have discovered that the difference between two consecutive captured values is always a multiple of 6, which means that the resolution is 6 time lower than expected. Why is it? Is it possible to improve it? Our application needs a high resolution.
Below is a piece of code. We use µVision3 V3.90.
Thank you in advance
Thierry
// initialization
    POWKEY1 = 0x1;
    POWCON0 = 0x78;           // Set core to max CPU speed of 10.24Mhz
    POWKEY2 = 0xF4;
T0CON = BIT17 + BIT16 + BIT10 + BIT8 + BIT7;    // BIT17 = enable capture ; BIT16 event to monitor; BIT10 = Clock 10.24 MHz ; BIT8 = count up ; BIT7 = enable ; free running, No prescaler
    IRQCONE = BIT5; // BIT5 = triggers on rising edge
    IRQEN = BIT18; // BIT18 = activate XIRQ2 external interrupt.
    IRQEN = BIT3;  // Enable Timer 0 IRQ
// interrupt routine
void IRQ_Handler(void) __irq
     if ((IRQSTA & BIT18) == BIT18)    //XIRQ2 : pin P2.0/IRQ2/PWM0/EXTCLK
        IRQCLRE = BIT18; // interrupt aknowledged
        dwCapture = T0CAP;
        dwPeriodeIn = dwCapture - dwCapturePrev; // allways a multiple of 6
        dwCapturePrev = dwCapture;
