AD9854 difference between RFSK and CHIRP
Question asked by RobS on Jan 20, 2012
Latest reply on Oct 16, 2012 by Sudhanshu
We at our company are using the AD9854 and have encountered some strange behavior between the CHIRP mode and the RFSK mode.
In the RFSK mode the delta frequency can be clearly seen when the signal is analyzed on the SA. However when changing the mode from RFSK to chirp we get a completely different response.
Are these measurements the expected behavior?
Are there some special things we need to take into account when using the CHIRP mode or in general on working with DDS?
Are we preforming the measurement correctly?
Kind Regards
Rob
Mode: RFSK
Ref clock: 30MHz
Ref. multiplier:10
Delte frequency: 100 kHz
Start frequency : 10MHz
Stop frequency: 35MHz
Rampe rate (pulse time): 100ns
With these settings we can clearly distinguish the delta frequency
Mode: Chirp
Ref clock: 30MHz
Ref. multiplier:10
Updateclock: 34µs <=> Stop frequency: 35MHz
The measured deltafrequency  is now only 30 KHz while the only thing changed is the mode.
Mode: Chirp
Ref clock: 30MHz
Ref. multiplier:10
Updateclock: 10.2µs <=> Stop frequency: 35MHz
Rampe rate (pulse time): 30ns
When changing the ramp rate to 30ns we get to see the deltafrequency we expected.
