william111
We found a serious problem about  ADIS16467-1BMLZ
Discussion created by william111 on Aug 12, 2018
Latest reply on Aug 13, 2018 by NevadaMark
Hi, We found a serious problem about  ADIS16467-1BMLZ:
When angular rate over 200 deg/sADIS16467-1BMLZ’s Gyro output will reverse and jump to opposite side!
We have four ADIS16467-1BMLZ,and all of them have the same problem!
And we also have some ADIS16460AMLZ ,we test ADIS16460AMLZ and ADIS16467-1BMLZ in the same condition,the ADIS16460AMLZ is all right.But all of the ADIS16467-1BMLZ has the”output reverse over 200 deg/s”problem.
The Evaluation Boards and software that we used are list as blow:
1EVAL-ADIS2Z
2ADIS16IMU4/PCBZ
3IMU EVALUATION SOFTWARE(v1.18.9)
The test input signal is 2Hz~3Hz  SIN singal ,just like the following figue:
The following figue is The ADIS16460AMLZ’s correct responds  ,when angular rate over the +max range or –max range,the gyro’s output will keep it’s max output until angular  rate fallen back in gyro’s Dynamic Range.
The following figue is ADIS16467-1BMLZ’s problem: When angular rate over 200 deg/sADIS16467-1BMLZ’s Gyro output will reverse and jump to opposite side!
Please tell me how can I solve this problem?
