BF706 Fir filter codec problem?
Question asked by jie070428 on Aug 9, 2018
Latest reply on Aug 14, 2018 by jie070428
This is my programming code for the fir filter, I use the filter header file in the routine, my filter coefficient uses the data type long double, and my program uses the fract32 type, I have data on it. Conversion. I have been unable to achieve the effect of the fir filter, I hope you can help me solve it, or can you upload your fir program code? Thank you very much!
#include <filter.h>
#include <fract2float_conv.h>
#include <fract.h>
#include "AudioCallback.h"
#define NUM_STAGES 19
#define SAMPLES_PER_CHAN 32
fract32 inLeft[SAMPLES_PER_CHAN];
fract32 inRight[SAMPLES_PER_CHAN];
fract32 outLeft[SAMPLES_PER_CHAN];
fract32 outRight[SAMPLES_PER_CHAN];
/* Filter coefficients generated by a filter design tool */
long double a_coeffs_low_1khz[ NUM_STAGES+ 1] = {
0.0056875030502704814L,
0.0077454009452989012L,
0.013373821271223L,
0.022490889801401574L,
0.034509874043985686L,
0.048390349721389926L,
0.062759053391392025L,
0.076084405100706562L,
0.08687990466444219L,
0.093906594457164302L,
0.013373821271223L,
0.0056875030502704814L};
fract32 long_double_to_fr32 (long double a_coeffs_low_1khz);
/* Coefficients and delay line for the iir function */
fract32 df1_coeffs[(2 * NUM_STAGES) + 2];
fract32 delayLeft[(2 * NUM_STAGES) + 2];
fract32 delayRight[(2 * NUM_STAGES) + 2];
fir_state_fr32 stateLeft;
fir_state_fr32 stateRight;
/* initialize the IIR filter */
void FilterInit(FILTER_MODE mode)
int i;
/* Configure filter state */
fir_init (stateLeft, a_coeffs_low_1khz, delayLeft, (NUM_STAGES+1),1);
fir_init (stateRight, a_coeffs_low_1khz, delayRight, (NUM_STAGES+1),1);
/* Zero delay line to start or reset the filter */
for (i = 0; i < ((2 * NUM_STAGES) + 2); i++)
delayLeft[i] = 0;
delayRight[i] = 0;
/* Compute filter response */
void AudioFilter(const fract32 dataIn[], fract32 dataOut[])
int n;
int i;
/* separate channels (2D DMA would be better) */
i = 0;
for (n=0; n<SAMPLES_PER_CHAN; n++){
inLeft[n] = dataIn[i++];
inRight[n] = dataIn[i++];
/* left channel filter */
fir_fr32 (inLeft, outLeft, SAMPLES_PER_CHAN, &stateLeft);
/* right channel filter */
fir_fr32 (inRight, outRight, SAMPLES_PER_CHAN, &stateRight);
/* combine channels (2D DMA would be better) */
i = 0;
dataOut[i++] = outLeft[n];
dataOut[i++] = outRight[n];
