Question about saferoad address of ADAU1466
Question asked by Andrew.Choi on Aug 6, 2018
Latest reply on Aug 12, 2018 by Andrew.Choi
Hi all
I have a question about saferoad address of ADAU1466
The development environment uses adau1466 / SigmaStudio 4.1.
1. In table 55 of the datasheet, I found the information about safeload address.
2. The compile_output.log file from sigmastudio (ver 4.1).
3. SigmaStudio Capture window
Question
1. Which Safeload addresses should use in my environment?
2. The address_SafeLoad entry in Safeload address + 5
    #define MOD_MIDFILTER1_ALG0_STAGE2_B2_ADDR             91
If I want to set the value above, which value should you enter as either 0x0000005b or 0x5b000000?
3. What does num_Safeload_Lower / num_Safeload_Upper at safeload address + 6,7 judge Lower / Upper based on?
Which of the following is MOD_MIDFILTER1_ALGO_STAGE2_B2_ADDR Lower or Upper?
I attached SigmaStudio project file and compiler_output.log.
Please advise the above question.
Thank you
