Question about ADXL362 Offset
Question asked by Kazu on Jul 31, 2018
Latest reply on Jul 31, 2018 by jwang
A couple of ADXL362 show abnormal outputs on Y and Z axis after working for about 2 weeks in the field.
These outputs were no problem (showed correct values) at my shipping test but returned abnormal devices output
fix values, for instance Y=0xF800 and Z=0x67FF, and these values do not change even though adding acceleration
intentionally. Mesurement range: +/-2g,  Power supply: VS=VDDIO=3.3V.
I have mostly come to be able to use abnormal ADXL362s (but probably not a fundamental solution) by software offset
cancel (measuring real offset values and cancel them) in +/-8g range.
  • Can you think of anything that might have caused the large offset?
         According to the data sheet, Offset vs Temperature is 0.6mg/C typ and delta T is at most 40 degC in the field,
         so offset drift is calculated to 24mg (very small).
  • Any problem about the way to read data.
         My sequence reads sensing data once a second after confirming the status register to know new data is ready to
         be read, but do not use interrupt signals from the ADXL362 as trigger.
Kazu
