failure to sync on AD9957
Question asked by timothy.starr on Jan 9, 2012
Latest reply on Feb 22, 2012 by DSB
We are having problems with AD9957 multi-chip synchronization.
AD9957 REF_CLK is provided with 20MHz clock input, SYNC_IN is provided with 100KHz clock input. SYSCLK is set at 1GHz. The PLL is locked, but we see the Synchronization Sample Error (SNC_SMP_ERR high). Adjusting input delay takes no effect
The AD9957 register setting is:
CFR1: 0x 00400002
CFR2: 0x 00402800
CFR3: 0x 0518C164
Multichip Sync: 0x 08000000
We have tried to lower the SYSCLK to 400MHz, and adjust the input delay, the synchronization seems to work. The following is the register set up:
CFR1: 0x 00400002
CFR2: 0x 00402800
CFR3: 0x 0018C128
Multichip Sync: 0x 08000020
We need to run at 1GHz sysclk, though.
Could you take a look at it?
Is there atiming requirement for the sync input set up and hold requirement with regard to the SYSCLK?.
Thank you. And best regards
Tim Starr on behalf of JW@AC.
