Custom board booting with u-boot failed
Question asked by Quamstar on Jul 27, 2018
Latest reply on Aug 3, 2018 by Quamstar
we have developed our own hardware, which is similar to the ZC702 with the FMCOMMS5-EZB. We have removed and added some interfaces, but basically the design/architecture is the same. Obviously the PL and the XDC files have been modified, since we are not having the same schematic. Nevertheless, we have some issue bringing up the board.
We were able to build and execute the FSBL from SDK and also running some no-os applications (hello world, memery test etc.). Now we are trying to start the linux os system. Unfortunalely, we have some issues with u-boot, which seems not to be executed. We tried to use JTAG boot mode and SD boot mode. Here is the debug response from UART:
Xilinx First Stage Boot Loader
Release 2016.2<9>Jul 26 2018-12:11:32
Devcfg driver initialized
Silicon Version 3.1
Boot mode is SD
SD: rc= 0
SD Init Done
Flash Base Address: 0xE0100000
Reboot status register: 0x60400000
Multiboot Register: 0x0000C000
Image Start Address: 0x00000000
Partition Header Offset:0x00000C80
Partition Count: 3
Partition Number: 1
Header Dump
Image Word Len: 0x0009B120
Data Word Len: 0x0009B120
Partition Word Len:0x0009B120
Load Addr: 0x00000000
Exec Addr: 0x00000000
Partition Start: 0x000075D0
Partition Attr: 0x00000020
Partition Checksum Offset: 0x00000000
Section Count: 0x00000001
Checksum: 0xFFE2745E
Bitstream
In FsblHookBeforeBitstreamDload function
PCAP:StatusReg = 0x40000A30
PCAP:device ready
PCAP:Clear done
Level Shifter Value = 0xA
Devcfg Status register = 0x40000A30
PCAP:Fabric is Initialized done
PCAP register dump:
PCAP CTRL 0xF8007000: 0x4C00E07F
PCAP LOCK 0xF8007004: 0x0000001A
PCAP CONFIG 0xF8007008: 0x00000508
PCAP ISR 0xF800700C: 0x0802000B
PCAP IMR 0xF8007010: 0xFFFFFFFF
PCAP STATUS 0xF8007014: 0x00002A30
PCAP DMA SRC ADDR 0xF8007018: 0x00100001
PCAP DMA DEST ADDR 0xF800701C: 0xFFFFFFFF
PCAP DMA SRC LEN 0xF8007020: 0x0009B120
PCAP DMA DEST LEN 0xF8007024: 0x0009B120
PCAP ROM SHADOW CTRL 0xF8007028: 0xFFFFFFFF
PCAP MBOOT 0xF800702C: 0x0000C000
PCAP SW ID 0xF8007030: 0x00000000
PCAP UNLOCK 0xF8007034: 0x757BDF0D
PCAP MCTRL 0xF8007080: 0x30800100
DMA Done !
FPGA Done !
n FsblHookAfterBitstreamDload function
Partition Number: 2
Header Dump
Image Word Len: 0x00020E2E
Data Word Len: 0x00020E2E
Partition Word Len:0x00020E2E
Load Addr: 0x04000000
Exec Addr: 0x04000000
Partition Start: 0x000A26F0
Partition Attr: 0x00000010
Checksum: 0xF7EFAC14
Application
Handoff Address: 0x04000000
In FsblHookBeforeHandoff function
SUCCESSFUL_HANDOFF
FSBL Status = 0x1
UNDEFINED_HANDLER
FSBL Status = 0xA301
This Boot Mode Doesn't Support Fallback
In FsblHookFallback function
We were using the same u-boot as did with the evaluation boards, the ps7_init has been changed with the custom board settings.
Do you have any idea what goes wrong?
Thanks and kindly regards
Jan
