Can I put the stack in external memory (on TigerSHARC)
Question asked by seabird on Jan 8, 2012
Latest reply on Jan 11, 2012 by seabird
   Hi, I have a problem when I want to put the stack in external memory, because there is a saying in visual DSP mannual "As the stack is assumed to be located in internal memory, the compiler and run-time libraries make use of loads directly into sequencer registers which would be illegal were the stack to be placed in external memory."  So, I do follow to solve this problem, First I eidt the LDF file to point the stack to external memory, and then I recompile the run time liberary. There is makefile in the lib src path, but I dont know how to use it to recompile the run time lib. Thanks for your help!
Best regards!
seabird
2012.1.8
