Codec ad74111 interface
Question asked by pietrodcs on Jan 6, 2012
Latest reply on Jan 23, 2012 by pietrodcs
Good morning.
Happy new year for all of YOU.
I am fighting to have the codec AD74111 to work. I have prepared something like the AD7311 which
has been working successfully before. Actually the setting for the sport are identical.
I have verified on the scope the signals for the DIN of the codec and it is working.
What I do is the same I read on the document EVAL-AD74111EB for the 16-BIT DATA MODE, 16-BIT DATA, MASTER MODE.
I send the registers in the same order. I send the register A four times with a zero in between ( I don t know why it is necessary) ,
the last register is D.
I tried to send two times each register, I mean two times A, two times B ecc.... just to verify if there is a question of synch between control and
DAC data, but it is the same.
I attach and dump the code for the initialization
    Here it is for sending the list of config registers
    The sport is left disabled
    The Sport should be reinit for serving the comms
// #pragma section("FLASH_code")
static void Sport_Config_Init( void ) {
    // This is not here requiring the RX side init
    // The SPORT will be : late frame synch, active high, ext clk, MSB first, Norm op, ext frame synch, require frame synch
    // secondary disable word length 16
    *pSPORT_TCR1 = TFSR;
    *pSPORT_TCR2 = 0x0F;
    *pSPORT_STAT = TXHRE;
    *pSPORT_STAT = TOVF;
    *pSPORT_STAT = TUVF;
    *pSPORT_STAT = RUVF;
    *pSPORT_STAT = ROVF;
static void SportTxEnable( void ) {
    *pSPORT_TCR1 |= TSPEN;
// #pragma section( "FLASH_code" )
int Ad74111_Config_Init( void ) {
    // unsigned short ctrl_regs[8];
    unsigned short status = 0;
    static volatile int count = 0;
    TRegA RegA;
    TRegB RegB;
    TRegC RegC;
    TRegD RegD;
    TRegE RegE;
    // TRegF RegF;
    TRegG RegG;
    RegA.rw = Erw_write;
    RegA.Addr = REGA_ADDR;
    RegA.Res = 0;
    RegA.Reserv = 0;
    RegA.ADCInpAmp = EOn;
    RegA.ADCOn = EOn;
    RegA.DACOn = EOn;
    RegA.RefOn = EOn;
    RegA.RefAmpOn = EOn;
    RegA.Res2 = 0;
    RegB.rw = Erw_write;
    RegB.Addr = REGB_ADDR;
    RegB.Res = 0;
    RegB.Reserv    = 0;
    RegB.clk3_div = EMclk3_div1;
    RegB.clk2_div = EMclk2_div3;
    RegB.clk1_div = EMclk1_div1;
    RegC.rw = Erw_write;
    RegC.Addr = REGC_ADDR;
    RegC.Res = 0;
    RegC.Reserv    = 0;
    RegC.ADDAWidth = EADDA_Len16;
    RegC.LowDelay = EEnable;
    RegC.DACDeEnph = EDACDeEnph_None;
    RegC.ADCHPass = EEnable;
    RegD.rw = Erw_write;
    RegD.Addr = REGD_ADDR;
    RegD.Res = 0;
    RegD.MFrame    = EMFrame_Normal;
    RegD.Reserv = 0;
    RegD.DMode = EDMode_Data;
    RegD.DspMode = EDspMode_16;
    RegD.FastDClk = EFastDClk_256;
    RegD.MSMode    = EMSMode_Master;
    RegE.rw = Erw_write;
    RegE.Addr = REGE_ADDR;
    RegE.Res = 0;
    RegE.Reserv    = 0;
    RegE.ADCL_PkEn = EDisable;
    RegE.ADCGain = EADCGain_9dB;
    RegE.ADCMute = EDisable;
    RegE.DACMute = EDisable;
    RegF.rw = Erw_write;
    RegF.Addr = REGF_ADDR;
    RegF.Res = 0;
    RegF.Reserv    = 0;
    RegF.InpPeak = 0;
    RegG.rw = Erw_write;
    RegG.Addr = REGG_ADDR;
    RegG.Res = 0;
    RegG.DACVol = 0;
    Ad74111_IO_Init();
    // Sport_Config_Init();
    for (count = 0; count < 100000; count++);
    RESET_LOW;
    RESET_HI; // tRH  5MCLKS
    ssync();
    /* SPORT Tx Register is a 8 x 16 FIFO, all the data can be put to
     * FIFO before enable SPORT to transfer the data
    *pSPORT_TX16 = RegA.W;
    *pSPORT_TX16 = 0;
    *pSPORT_TX16 = 0;
    *pSPORT_TX16 = 0;
    *pSPORT_TX16 = 0;
    *pSPORT_TX16 = RegB.W;
    *pSPORT_TX16 = RegC.W;
    *pSPORT_TX16 = RegE.W;
    status = *pSPORT_STAT;
    ssync();
    SportTxEnable();
    ssync();
    count = 0;
    while ( (status & TXF) && (count++ < TIMEOUT) ) {
        int cnt;
        for (cnt = 0; cnt < 1000; cnt++);
        ssync();
        int cnt;
        ssync();
    if ( count >= TIMEOUT )    goto LExit;
    *pSPORT_TX16 = 0;
        int cnt;
        ssync();
        int cnt;
        ssync();
    *pSPORT_TX16 = 0;
        int cnt;
        ssync();
        int cnt;
        ssync();
    *pSPORT_TX16 = 0;
        int cnt;
        ssync();
    *pSPORT_TX16 = RegG.W;
        int cnt;
        ssync();
    *pSPORT_TX16 = 0;
        int cnt;
        ssync();
    *pSPORT_TX16 = RegD.W;
        int cnt;
        ssync();
    *pSPORT_TX16 = 0;
    /* When TUVF is set, the data is already send out */
    while (!(status & TUVF) && count++ < TIMEOUT) {
        int cnt;
        // udelay(1);
        ssync();
LExit:
    *pSPORT_STAT = TXF;
    SportTxDisable();
    // bfin_write_SPORT_TCR1(bfin_read_SPORT_TCR1() & ~TSPEN);
    ssync();
    // local_irq_enable();
    if (count >= TIMEOUT) {
        return -1;
    return 0;
I hope You find the arcan
Thank You
