AD9364 Tx PLL unlock
Question asked by Hugh on Jul 22, 2018
Latest reply on Jul 24, 2018 by sripad
The TX RF PLL cannot be locked, but the RX RF PLL can be.I configured the TX RF PLL to 2500MHz and its reference frequency is 80MHz.I tried it many times, but I can't lock it.
My configuration file is as follows:
// Setup RF PLL non-frequency-dependent registers
SPIWrite 261,00 // Set Rx LO Power mode
SPIWrite 2A1,00 // Set Tx LO Power mode
SPIWrite 248,0B // Enable Rx VCO LDO
SPIWrite 288,0B // Enable Tx VCO LDO
SPIWrite 246,02 // Set VCO Power down TCF bits
SPIWrite 286,02 // Set VCO Power down TCF bits
SPIWrite 249,8E // Set VCO cal length
SPIWrite 289,8E // Set VCO cal length
SPIWrite 23B,80 // Enable Rx VCO cal
SPIWrite 27B,80 // Enable Tx VCO cal
SPIWrite 243,0D // Set Rx prescaler bias
SPIWrite 283,0D // Set Tx prescaler bias
SPIWrite 23D,00 // Clear Half VCO cal clock setting
SPIWrite 27D,00 // Clear Half VCO cal clock setting
SPIWrite 015,0C // Set Dual Synth mode bit
SPIWrite 014,1D // Set Force ALERT State bit
SPIWrite 013,01 // Set ENSM FDD mode
WAIT 1 // waits 1 ms
SPIWrite 23D,04 // Start RX CP cal
WAIT_CALDONE RXCP,100 // Wait for CP cal to complete, Max RXCP Cal time: 460.800 (us)(Done when 0x244[7]==1)
SPIWrite 27D,04 // Start TX CP cal
WAIT_CALDONE TXCP,100 // Wait for CP cal to complete, Max TXCP Cal time: 460.800 (us)(Done when 0x284[7]==1)
SPIWrite 23D,00 // Disable RX CP Calibration since the CP Cal start bit is not self-clearing. Only important if the script is run again without restting the DUT
SPIWrite 27D,00 // Disable TX CP Calibration since the CP Cal start bit is not self-clearing. Only important if the script is run again without restting the DUT
// FDD RX,TX Synth Frequency: 2400.000000,2500.000000 MHz
// Setup Rx Frequency-Dependent Syntheisizer Registers
SPIWrite 23A,4A // Set VCO Output level[3:0]
SPIWrite 239,C0 // Set Init ALC Value[3:0] and VCO Varactor[3:0]
SPIWrite 242,0D // Set VCO Bias Tcf[1:0] and VCO Bias Ref[2:0]
SPIWrite 238,68 // Set VCO Cal Offset[3:0]
SPIWrite 245,00 // Set VCO Cal Ref Tcf[2:0]
SPIWrite 251,09 // Set VCO Varactor Reference[3:0]
SPIWrite 250,70 // Set VCO Varactor Ref Tcf[2:0] and VCO Varactor Offset[3:0]
SPIWrite 23B,91 // Set Synth Loop Filter charge pump current (Icp)
SPIWrite 23E,D4 // Set Synth Loop Filter C2 and C1
SPIWrite 23F,DF // Set Synth Loop Filter R1 and C3
SPIWrite 240,09 // Set Synth Loop Filter R3
// Setup Tx Frequency-Dependent Syntheisizer Registers
SPIWrite 27A,4A // Set VCO Output level[3:0]
SPIWrite 279,C0 // Set Init ALC Value[3:0] and VCO Varactor[3:0]
SPIWrite 282,0D // Set VCO Bias Tcf[1:0] and VCO Bias Ref[2:0]
SPIWrite 278,70 // Set VCO Cal Offset[3:0]
SPIWrite 285,00 // Set VCO Cal Ref Tcf[2:0]
SPIWrite 291,09 // Set VCO Varactor Reference[3:0]
SPIWrite 290,70 // Set VCO Varactor Ref Tcf[2:0] and VCO Varactor Offset[3:0]
SPIWrite 27B,8F // Set Synth Loop Filter charge pump current (Icp)
SPIWrite 27E,D4 // Set Synth Loop Filter C2 and C1
SPIWrite 27F,DF // Set Synth Loop Filter R1 and C3
SPIWrite 280,09 // Set Synth Loop Filter R3
// Write Rx and Tx Frequency Words
SPIWrite 233,00 // Write Rx Synth Fractional Freq Word[7:0]
SPIWrite 234,00 // Write Rx Synth Fractional Freq Word[15:8]
SPIWrite 235,00 // Write Rx Synth Fractional Freq Word[22:16]
SPIWrite 232,00 // Write Rx Synth Integer Freq Word[10:8]
SPIWrite 231,78 // Write Rx Synth Integer Freq Word[7:0]
SPIWrite 005,11 // Set LO divider setting
SPIWrite 273,00 // Write Tx Synth Fractional Freq Word[7:0]
SPIWrite 274,00 // Write Tx Synth Fractional Freq Word[15:8]
SPIWrite 275,00 // Write Tx Synth Fractional Freq Word[22:16]
SPIWrite 272,00 // Write Tx Synth Integer Freq Word[10:8]
SPIWrite 271,7D // Write Tx Synth Integer Freq Word[7:0] (starts VCO cal)
SPIRead 247 // Check RX RF PLL lock status (0x247[1]==1 is locked)
SPIRead 287 // Check TX RF PLL lock status (0x287[1]==1 is locked)
