AD9371 receive path spikes
Question asked by john26 on Jul 18, 2018
Latest reply on Jul 30, 2018 by Vinod
I have started to see spikes in the data from the AD9371 receiver and would like to understand the cause and eliminate them.
Initially I tested the AD9371 with the default centre frequency of 2.55GHz. The data was captured from JESD into RAM and analysed over of a range of test tone frequencies and amplitudes. The amplitudes were measured in -10dbm intervals down to -100dbm and no-signal. At the lower end the output was noise in the range of +/-10 counts.
Altering the centre frequency to 1.3GHz and re-measuring now shows single sample noise spikes in the input signal when significantly lower than 8-bits (eg/ +/-40 counts). Spikes are in the range -256 to -249 counts, and +248 to +255 appear over about 1% of the samples (example time domain plot of captured test data attached showing problem).
I am surprised that just changing the centre frequency would cause this, however now I am wondering about the LO/PLL and problems with it, and things like decoupling. The hardware is a AD9371 evaluation board.
Any ideas as to the cause of this and how to eliminate the source of the noise?
