ADA2200 - Circuit Example Suggests 125kHz Demod Operation?
Question asked by JeffreyGage on Jul 12, 2018
Latest reply on Jul 17, 2018 by JeffreyGage
The context for this question is as a high frequency response LVDT Signal Conditioner.
I was looking at the ADA2200 datasheet when I came across this passage in applications information:
ADA Datasheet pg17
From what I see here it suggests that the ADA2200 can be run using a 1MHz clock and can output demod at 125 kHz.
Question 1: Doesn't the datasheet say that a max 500kHz clock should be used and that only up to a ~30kHz output can be attained (~60 kHz output sample rate, ~30kHz after Nyquist)? Did I miss something?
Question 2: Is the multiplexer ADC viable for increasing output frequency on one channel? It shows application for multiple channels, but what if I used the same channel as inputs? Could I use two ADA2200 units in the formation suggested above and get 60kHz out?
