AD9172 custom design mismatching jesd204 parameters
Question asked by LCr on Jul 10, 2018
Latest reply on Jul 17, 2018 by LCr
I'm currently developing a project based on the AD9172. For that purpose, I bought one eval board and the ADS7v2.
They work correctly together and now I want to use another FPGA board (the ZCU102), so I designed a simple FPGA project based on the JESD204 IP from Xilinx.
I want to use JESD204 mode 2 (3 lanes). I configured the IP like this (IP core shared in design):
I program the FPGA and then I set the DAC with ACE like this:
I must change some registers because my clocking scheme is the following:
For the AD9172:
Registers
Value
Comments
0x308
0x8
physical lane 0 correspond to logical lane 0, phy 1 to log 1 etc.
0x309
0x10
0x95
0x0
Enable PLL
0x790
0
Required
0x791
0
Required
0x796
0xE5
Required
0x7A0
0xBC
Required
0x794
0x08
Recommended CP current
0x797
0x10
Required
0x797
0x20
Required
0x798
0x10
Required
0x7A2
0x7F
Required
Pause 100 ms
0x799
0xC3
Output clk = dac clock /4, N div=3
0x793
0x18
Input divider = 1
0x94
0x00
DAC clock = VCO / 1
0x792
0x2
Reset VCO
0x792
0
Pause 100 ms
0x7B5
READ
If locked, equals 1
For the HMC7044:
Registers
Value
Comments
3
0x2C
Disable PLLs
5
0x6F
CLKIN1 as external VCO input
0x64
0x1
External VCO
0xED
0
CLKOUT3 output mux = channel divider
0x151
0
CLKOUT13 output mux = channel divider
0x14B
0x40
CLKOUT13 divided by 64 -> 500 / 64 = 7.8125 = sysref to FPGA
0x14C
0
0xE7
0x40
CLKOUT3 divided by 64 -> 500 / 64 = 7.8125 = sysref to DAC
0xE8
0
0xE3
0
CLKOUT2 output mux = channel divider
0x147
0
CLKOUT12 output mux = channel divider
0xDE
0
CLKOUT2 divided by 2 -> 500 / 2 = 250 = data rate clock unused because external dac clock
0xDD
0x2
0x142
0
CLKOUT12 divided by 2 -> 500 / 2 = 250 = data rate clock to FPGA
0x141
0x2
