Dual AD2S1210 on SPI bus
Question asked by ianstedman on Jul 4, 2018
I am working on a system that uses 2x AD2S1210 devices connected via a SPI bus to a NXP MPC5674 Microcontroller. We are having some intermittent issues with corruption of data read from the device. I have been asked to review the usage of the device and upon reading the manual, I'm a bit confused.
In the serial interface section of the datasheet, it states:
The falling edge of WR/FSYNC takes the SDI and SDO
lines out of a high impedance state. A rising edge on WR/FSYNC
returns the SDI and SDO to a high impedance state. The CS input
is not required for the serial interface and should be held low.
Now in our system, we have 2 x chip-selects, one per AD2S1210 and a shared WR/FSYNC signal. Reading the manual, it would suggest that in my system, when WR/FSYNC is driven low, the SDO outputs of both devices will be driven, regardless of the CS input, is this correct?
We have got around some earlier issues by doing a dummy read from the device before getting the data required but there are still intermittent issues.
We permanently use the device in configuration mode, so A0 & A1 are set to logic 1. Currently we are using SPI mode 2 (CPOL=1, CPHA=0), will change this to SPI mode 3 (CPOL=1, CPHA=1), to match your Linux driver.
Any help appreciated.
