ADXL345 change BW_RATE on running generate ACTIVITY interrupt
Question asked by Maurizio_IT on Jul 4, 2018
Latest reply on Jul 6, 2018 by neilzhao
Dear Analog Support team,
 I'm using ADX345 for al long time on my design. I want reduce the current when there isn't any movement of the peaple that is under tracking when INACTIVITY interrupt assert. I try to change the BW_RATE from 50Hz to 12,5Hz after INACTIVITY event, but it happen a ACTIVITY interrupt immeditly after this change.
Her is my corrent configuration:
  ADXL345_SetRegisterValue(ADXL345_POWER_CTL, 0x0); //standby mode at startup.
  ADXL345_SetRegisterValue(ADXL345_INT_ENABLE, 0x00); //disable interrupt
  register_val = ADXL345_GetRegisterValue(ADXL345_DEVID) ;//check ID if Read operation works
  if(register_val == ADXL345_ID)
   printf("ADXL345 WHOIAM[0xE5]=0x%x configure..", register_val );
  /*Chip inizialization. */
  ADXL345_SetRegisterValue(ADXL345_BW_RATE, XL345_RATE_50); //data rate
  ADXL345_CurrentDataRate = XL345_RATE_50;
  /*start INACTIVITY SETTING INT1 */
  ADXL345_SetRegisterValue(ADXL345_INT_MAP, 0x00); //map all on INT1
  ADXL345_SetRegisterValue(XL345_THRESH_INACT, 0x05);
  ADXL345_SetRegisterValue(XL345_TIME_INACT, 10);
  ADXL345_SetRegisterValue(XL345_ACT_INACT_CTL, XL345_INACT_Z_ENABLE|XL345_INACT_Y_ENABLE|XL345_INACT_X_ENABLE|XL345_INACT_AC);
  /*Start FIFO settings and watermark level */
  ADXL345_SetRegisterValue(ADXL345_FIFO_CTL, ADXL345_FIFO_MODE(ADXL345_FIFO_STREAM) | ADXL345_TRIGGER | ADXL345_SAMPLES(31)); //FIFO mode 0xF samples WTMK INT1
  ADXL345_SetRegisterValue(XL345_DATA_FORMAT, XL345_FULL_RESOLUTION | XL345_DATA_JUST_RIGHT | XL345_RANGE_16G);
 /*End FIFO settings */
  ADXL345_SetRegisterValue(ADXL345_INT_ENABLE,  ADXL345_WATERMARK |  ADXL345_FREE_FALL);
  ADXL345_SetRegisterValue(ADXL345_POWER_CTL, ADXL345_PCTL_MEASURE); //start to measure
When I detect INACTIVITY interrupt this the code when I try to change BW_RATE:
case ADXL_INACTIVITY:
    if( ADXL345_CurrentDataRate == XL345_RATE_50 )
     ADXL345_SetRegisterValue(ADXL345_POWER_CTL, 0x0); //standby mode to change registers
     ADXL345_SetRegisterValue(ADXL345_BW_RATE, XL345_RATE_12_5); //reduce data rate from XL345_RATE_50
     ADXL345_CurrentDataRate = XL345_RATE_12_5;
     ADXL345_SetRegisterValue(ADXL345_INT_ENABLE, ADXL345_ACTIVITY | ADXL345_INACTIVITY | ADXL345_FREE_FALL);
     ADXL345_SetRegisterValue(ADXL345_POWER_CTL, ADXL345_PCTL_MEASURE); //no sleep, measure active start again
After reduction of BW_RATE setting ADXL345 assert ACTIVITY interrupt bit, even it is stable on desk.
Why this happen?
How to avoid that and what is suggested procedure to change BW_RATE on fly (up scale and down scale)?
Thank you for support.
Regards
Maurizio
