Suppress assembler preprocessor warning syntax question
Question asked by devsm on Jul 3, 2018
Latest reply on Jul 12, 2018 by Reva@14
I am using CCES 2.5.1 and assembling for BF70X.
I am trying to suppress the assembler preprocessor warning pp0038.
I have tried the following command line switches:
-Wsuppress 38
-W38
Neither work for me and I always get the following assembling warnings, one where it tells me that 38 is an unknown message ID followed by a pp0038 warning.
  [Warning ea1195] "command-line":1 This number does not represent a known message id : 38
  [Warning pp0038] "ppasrc1.asm_bf70x":26 macro 'DEF_DEVICE' not currently defined - 0 assumed
I know my syntax is mainly correct because if, for example, I assemble with -W1195 -W38 then I only get the following:
which means -W1195 successfully suppressed the ea1195 warning.
So it must be something particular to preprocessor warnings. The assembler manuals states the following:
   The -Wnumber (warning suppression) switch selectively disables warnings specified by one or more message numbers.
   For example, -W74 disables warning message pp0074.
Can you let me know what I am doing wrong?
Thank you
