LTP5901-IPM, how should we tie nonuse UART input pins?
Question asked by Euglena on Jul 2, 2018
Please let me ask how we should treat nonuse UART pins.
I found following description in the LTP5901-IPM (Mote) data sheet.
When UART (Pin No.57-62) is not used, whether should we use pull-up or pull-down, for following three input pins?
If there are recommended resister value, could you please let me know?
When using pull-up resister, current from it is consumed, I am concerned.
I would like to reduce the current consumption as much as possible.
LTP5901-IPM/LTP5902-IPM / SmartMesh IP Node 2.4GHz 802.15.4e Wireless Mote Module
http://www.analog.com/media/en/technical-documentation/data-sheets/59012ipmfa.pdf
Page 22
No.57 UART_RX_RTSn
No.59 UART_RX
No.61 UART_TX_CTSn
Note 14: These inputs are always enabled and must be driven or pulled to a valid state to avoid leakage.
