AD6688-3000EBZ
Question asked by TERRY123 on Jun 26, 2018
Latest reply on Jun 27, 2018 by UmeshJ
I  am using AD6688-3000EBZ, ADS7-V2EBZ with ACE software.
I have some questions.
1. when no using DDC(Full band width mode, No DDC), the resolution of ADC is 7 bit. is that correct??
2. 915MHz (+10dBm Signal by using signal generator) is continuously applied to ADC A channel input.
the Setting : Sampling clock : 2.441 GHz DDC Mode ON (NCO Freq : 915MHz) , L = 4, M = 2, F = 1 N'=16, Line rate = 6.103Gbps, Decimation rate = 4.
But, the level of Fund Power is consistently changed.....
What is wrong with this....
Look at the pictures as below.
        <picture 1>
        <picture 2>
The test condition is fixed. not changed But Fund Power is consistently changed. (Picture 1 : -27dBFS Picture 2: -12dBFS)
3. When I start the ACE software, I can see the error message as below.
Actually, In the past, I used AD9208-3000EBZ with ACE Software.
But I could not see that message.
what is the problem?!
Thank you for ur help!!!
