ADALM-Pluto non-cyclic continues transmit
Question asked by New@Pluto on Jun 25, 2018
Latest reply on Jun 27, 2018 by travisfcollins
I am attempting to transmit internally generated signal via the AD9361. Software runs on target (Adalm-pluto).
The samples are generated for 20mS transmission. The time is measured
and takes about 8mS (7869498ns - 8049387ns)
To minimize process time I am using the buffer created by iio_device_create_buffer() to store the
generated samples.
There is always '1' in Status register   iio_device_reg_read(tx, 0x80000088, &val);
The same code is running on host computer without any problems.
What I'm doing wrong?
Thanks.
while(!Stop)
initialization
    tx_buffer = iio_device_create_buffer(tx, iq_buff_size, false);
    if (!tx_buffer) {
        perror("Could not create TX buffer");
        stop();
    char *ptx_buffer = (char *)iio_buffer_start(tx_buffer);
    mybuff = (const uint16_t**)ptx_buffer;
printf ("iio_buffer_set_blocking_mode = %d\n",iio_buffer_set_blocking_mode(tx_buffer, true));
            clock_gettime(CLOCK_MONOTONIC_RAW, &tpStart);
               sample generation code
            clock_gettime(CLOCK_MONOTONIC_RAW, &tpEnd);
            timeDelta = tpEnd.tv_nsec - tpStart.tv_nsec;
            if(timeDelta < 0)
                timeDelta += 1000000000;
           bytesTramsmitted = iio_buffer_push(tx_buffer);
           if(val == 1)
//            printf("Sratus register %d Time delta =  %ld\n",val, timeDelta);
          if(val)
               iio_device_reg_write(tx, 0x80000088, val);
