ADXL375 reaching 200g with small tap
Question asked by Tsibin on Jun 20, 2018
Latest reply on Jun 22, 2018 by jwang
Hello Everyone,
I am using ADXL375 sensor for the first time. I am using SPI at 2 MHz with sensor ODR = 3200 Hz. The settings I am using is as follows.
0x2C -> 0x0F
0x38 -> 0x90
0x2F -> 0xF9
0x2E -> 0x00
0x31 -> 0x0B
0x2D -> 0x08
I am enabling FIFO and reading the FIFO status before reading the data. I am doing multiple byte read for the reading raw datas. During my tests I am getting values between 4095 and -4096. But even with a small tap (with pencil) on the sensor PCB, I am getting around 200g on one axis (4090 raw counts on z axis). Is this expected ?
If I drop the sensor board from 2 cm above the table, I am getting max counts on z axis. I am assuming that 200g is a large force so I am confused when my sensor is reading 200g with the above tests.
My self test results are as follows.
Xst = 1.7g
Yst = -1.8g
Zst = 6.1g
Is there anything wronge with the settings or the sensor, or am i doing anything wronge? Any suggestion would be helpful.
Thanks.
