external SRAM for data access of 21489
Question asked by ThomasKracke on Dec 23, 2011
Latest reply on Jan 5, 2012 by Mitesh
my problem is, that existing C-code form 21369 does not allways work on external SRAM-memory of 21489.
SRAM has a width of 16 bits.
This are the affected vectors in external memory (CS1) of 21489:
Symbol Demangled name Address Size Binding
_FFT_Window_Hanning_4096FFT_Window_Hanning_40960x40040000x1000GLOBAL
_FFT_Window_Hanning_512FFT_Window_Hanning_5120x40050000x200GLOBAL
_FPGA_Filter_0UFPGA_Filter_0U0x40052000x4b5GLOBAL
_fft_in.0fft_in.00x40056b60x1000LOCAL
_fft_out.1fft_out.10x40066b60x1000LOCAL
_fft_in.2fft_in.20x40076b60x200LOCAL
_fft_out.3fft_out.30x40078b60x200LOCAL
Relevant for the problem are '_FFT_Window_Hanning_4096', '_fft_in.0' and another vector 'Knock_Demo_B.Sum_k' located inside internal memory.
This is the failing operation:
It just multiplies sampled data with the window-function.
// prepare FFT:
  tUINT32 i = NUMBER_OF_SAMPLES;
  const tREAL32* src = Knock_Demo_B.Sum_k;       // internal memory
  const tREAL32* win = FFT_Window_Hanning_4096;  // external memory
  tREAL32* dst = fft_in;                         // external memory
  while (i)
    *dst = *src * *win;
    dst++;
    src++;
    win++;
    i--;
I know that this all is very slow in external memory, but it's fast enough  in this application and we need all internal memory for other things.
But the really bad thing is:
It does not work at all! Only every second value reaches the destination vector 'fft_in'. All other values contains 0 after this loop.
(This code worked for years on 21369-systems)
On the 21489 I have to insert just one nop and it works:
// prepare FFT:
   while (i)
    *dst = *src * *win;
    asm("nop;");
    dst++;
     src++;
     win++;
     i--;
In the assembler code below you can see, that this single nop as big effect to the coder.
But why do I hove to insert this nop?
And do I have to insert more nops in my code on other locations?
Thank you for any help!!!
Assembler-Code for not working C-Code:
.P75L50:
    r2=btgl r0 by r15, i4=modify(i5,m5);
    if sz jump (pc,.P75L76) (db);
    i3=_FFT_Window_Hanning_4096;
    i2=_fft_in.0;
.P75L81:
    r12=ashift r0 by -1;
    s12=r12;
.P75L85:
    bit set mode1 0x200000;
.P75L83:
.LN35:
// line 1015
    nop;                                    // Inserted to fix anomaly enter_simd.
    r12=r12-1;
    if eq jump (pc,.P75L105) (db);
    r1=dm(i3,2);
    // -- stall --
    r2=dm(i4,2);
.P75L107:
    lcntr=r12, do (pc,.P75L106_end) until lce;
.P75L106:
//   Loop at "Knock_Demo_.c" line 1014 col 11
//   This loop executes 2 iterations of the original loop in estimated 3
//   cycles.
//   Unknown Trip Count
//   Successfully found modulo schedule with:
//     Initiation Interval (II)                                  = 3
//     Stage Count (SC)                                          = 2
//     MVE Unroll Factor                                         = 1
//     Minimum initiation interval due to recurrences (rec MII)  = 1
//     Minimum initiation interval due to resources (res MII)    = 3.00
//   This loop's resource usage is:
//     define dm dag                   used   3 out of    3 (100.0%)
//     dm dag                          used   3 out of    3 (100.0%)
//     pm dag                          used   3 out of    3 (100.0%)
//     shift immediate                 used   3 out of    3 (100.0%)
//     memory access                   used   3 out of    6 ( 50.0%)
//     multifunction alu               used   1 out of    3 ( 33.3%)
//     multifunction float multiply    used   1 out of    3 ( 33.3%)
//     multifunction integer add sub   used   1 out of    3 ( 33.3%)
//     multifunction integer multiply  used   1 out of    3 ( 33.3%)
//     multifunction mult              used   1 out of    3 ( 33.3%)
//   Loop was vectorized by a factor of 2.
//   Vectorization peeled 1 conditional iteration from the back of the loop
//   because of an unknown trip count, possibly not a multiple of 2.
//   Consider using pragma loop_count to specify the trip count or trip modulo
//   in order to avoid conditional peeling.
    f1=f2*f1, r2=dm(i4,2);
    dm(i2,2)=r1;
.P75L106_end:
    r1=dm(i3,2);
    // end loop .P75L106;
//   End Kernel for Loop L106
Assembler-Code for working C-Code:
.P75L52:
    i4=modify(i5,m5);
    i2=_fft_in.0;
    lcntr=r2, do (pc,.P75L15_end) until lce;
.P75L15:
.LN35:
// line 1015
    r1=dm(i4,m6);
    r0=dm(i3,m6);
    f1=f1*f0;
    dm(i2,m6)=r1;
.P75L16:
.LN36:
// line 1022
    // ASM STATEMENT
    nop;
    // END ASM STATEMENT
.P75L17:
.P75L46:
    nop;
    nop;
.P75L15_end:
    nop;
.LN37:
// line 1014
    // end loop .P75L15;
//   End Loop L15
