CCES working too slow in debug mode with ADSP BF707 using ICE-1000
Question asked by AntonM on Jun 14, 2018
I have custom board with bf707 processor. It's required to receive some data from an external device on UART0 channel with using UART status interrupt handler.
Here is my UART configuration:
 *pREG_UART0_CLK = 0x80000238;  //115200 baud
*pREG_UART0_CTL = ADI_UART_ONE_STOPBIT|ADI_UART_WORDLEN_8BITS|ADI_UART_MODE_UART;
*pREG_UART0_CTL |= ENUM_UART_CTL_RX_IRQ_TH4;
*pREG_UART0_IMSK_SET |= BITM_UART_IMSK_SET_ERBFI|BITM_UART_IMSK_SET_ERFCI|BITM_UART_IMSK_SET_ERXS;
adi_int_InstallHandler(INTR_UART0_STAT,UART_RX0_ISR,0,true);
*pREG_UART0_CTL |= BITM_UART_CTL_EN;
and interrupt handler:
EX_HANDLER(INTR_UART0_STAT, UART_RX0_ISR)
   uint8_t z = 0;
   *pREG_PORTC_DATA_TGL |= BITM_PORT_FER_SET_PX14; //toggling FLG
   z=*pREG_UART0_RBR;
   //put z to FIFO
If my program boot from flash memory, then FLG pin is toggling synchronously on each received byte on and I see this process on oscilloscope.
But if I am using DEBUG mode and load program with EMU ICE-1000, then FLG starts toggling over 100-200ms after first byte on UART0_RX appear. UART_STAT.OE bit was already set in UART_RX0_ISR  register.
If I load *.dxe with CCES_runner.exe, FLG toggling correctly.
Is it CCES trouble in emulation with ICE-1000?
My previous projects was build  in Visual DSP and i haven't any problems with debug in emulation mode.
My PC configuration:
   Inter core i7, 8GB, Windows 7 64-bit. Crosscore 2.7.0.0.
