Reading from PPI causes Ezkit to reset
Question asked by d3g8q9 on Dec 22, 2011
Latest reply on Jan 18, 2012 by d3g8q9
I'm working on a project where I need to receive ADC readings over the PPI interface.  I've been having difficulties with reading more than 30 words (I need to read about 2500).  I'm using the BF-537.
I've moved back to the Ezkit Lite to try out some things, and found that the Ezkit resets after I start a PPI read.  As I've never reflashed my Ezkit I can see that it's reset because the LEDs do their cycling pattern.
I'm working within a VDK environment, I've configured GP Timer 5 as a PWM at 1.2 MHz, and connected it to the PPI0CLK.  I know that this is working because I can see it on the scope.
My source code is below
#define PPI_BUFFER_SIZE 35
static ADI_DEV_DEVICE_HANDLE    hPPIHandle;
static u16 ppiDataBuffer[PPI_BUFFER_SIZE];
static ADI_DEV_1D_BUFFER PpiInboundBuffer;
static void PpiCallback(
    void    *pAppHandle,
    u32     nEvent,
    void    *pArg
    /* CASEOF (event type) */
    switch (nEvent)
        /* CASE (buffer processed) */
        case ADI_DEV_EVENT_BUFFER_PROCESSED:
// A transmit has completed
VDK_C_ISR_PostSemaphore(kPPISem); // update transfer completed semaphore
adi_dev_Control(hPPIHandle, ADI_DEV_CMD_SET_DATAFLOW, (void *)FALSE);
            break;
        default:
        lastIntStatus = nEvent;
        break;
    /* return */
static void ppiInit(void)
    u32 nResult;
    ADI_DEV_CMD_VALUE_PAIR PPIConfig[] =
          //BJB-- the following selects 0 Frame Syncs
          { ADI_PPI_CMD_SET_CONTROL_REG,               (void *)0x387C                         }, /* 16 bit data, internal trigger, , 0FS, input, non-ITU mode */
          { ADI_DEV_CMD_SET_DATAFLOW_METHOD,          (void *)ADI_DEV_MODE_CHAINED     }, /* chained method    */
          { ADI_DEV_CMD_END,                              NULL                                   }
    /* Open Ppi */
    if(nResult = adi_dev_Open(
                              adi_dev_ManagerHandle,
                              &ADIPPIEntryPoint,
                              0,
                              0,
                              &hPPIHandle,
                              ADI_DEV_DIRECTION_INBOUND,
                              adi_dma_ManagerHandle,
                              NULL,
                              PpiCallback
                              )!=ADI_DEV_RESULT_SUCCESS)
        DriverError("PPI_Open", nResult);
    /* set config table */
    if(nResult = adi_dev_Control(
                                hPPIHandle,
                                ADI_DEV_CMD_TABLE,
                                PPIConfig
                                )!= ADI_DEV_RESULT_SUCCESS)
        DriverError("PPI_Cfg", nResult);
    return;
    Function:       Configure Ppi Buffers
                    configures the inbound and outbound buffers
                    configures callback on inbound buffer
    Description:
static void ppiRead(void)
    u32 nResult;
     memset(ppiDataBuffer, 0, PPI_BUFFER_SIZE);
     PpiInboundBuffer.Data                = &ppiDataBuffer[0];
     PpiInboundBuffer.ElementCount        = PPI_BUFFER_SIZE-1;
     PpiInboundBuffer.ElementWidth        = 2;
     PpiInboundBuffer.CallbackParameter   = NULL;
     PpiInboundBuffer.ProcessedFlag       = FALSE;
     PpiInboundBuffer.pNext               = NULL;
/* Submit inbound buffer */
    if(nResult = adi_dev_Read(
                              hPPIHandle,
                              ADI_DEV_1D,
                              (ADI_DEV_BUFFER *)&PpiInboundBuffer
        DriverError("PPI_read", nResult);
    /* Enable dataflow */
                                hPPIHandle,
                                (void *)TRUE
        DriverError("DataFlow", nResult);
void testPpi(void)
ppiInit();
ppiRead();
     while(PpiInboundBuffer.ProcessedFlag == FALSE);
     //I never get here!!
    debug_print(threadIdList.debugThreadId, "PPI test complete\n");
