Unstable jffs2 mount
Question asked by illishar on Dec 22, 2011
Latest reply on Mar 21, 2012 by James.Kosin
We have a problem with our jffs2 mount.
We've mounted a single partition from a nandflash to jffs2. It seems to be really unstable however. We're using the 2010 uclinux and u-boot on our custom bf526-ezbrd.
We often get jffs2 errors during boot. Different kind of errors. Rarely the same.
Could be something like:
uncorrectable error :
mtd->read(0x200 bytes from 0x1369000) returned ECC error
JFFS2 notice: (147) jffs2_get_inode_nodes: Node header CRC failed at 0x1369000. {00db,0000,00000000,00000000}
mtd->read(0x44 bytes from 0x1369200) returned ECC error
JFFS2 error: (147) jffs2_do_read_inode_internal: CRC failed for read_inode of inode 4 at physical location 0x1369200
iget() failed for ino #4
JFFS2 notice: (147) jffs2_get_inode_nodes: Node header CRC failed at 0x1369200. {1616,1616,16161616,16161616}
It could be due to the "reboot" command which is a rather cruel reset. But "reboot" or "power shortage" the hw have to be able to handle both.
The nand is attached to the async mem interface and we've experimented with different timings and settings, both in linux and u-boot. We've also tried different mount options like eg. "-o sync". Nothing helps.
Also sometimes we even get kernel panics. After which the hw needs to be reset by hand. *Very critical*!
NULL pointer access
Kernel OOPS in progress
Deferred Exception context
CURRENT PROCESS:
COMM=opcd PID=147  CPU=0
TEXT = 0x01880040-0x018c83e0        DATA = 0x018c8400-0x018d5918
BSS = 0x018d5918-0x018dc0b0  USER-STACK = 0x018e0fa0
return address: [0x006829c0]; contents of:
0x006829a0:  3007  0127  05b4  0010  e14a  0008  e10a  7cf0
0x006829b0:  3045  0062  9162  3208  6019  a050  5608  b050
0x006829c0: [acca] 0c42  1807  0000  0000  9152  a050  5608
0x006829d0:  b050  a169  2fc1  6007  2fc6  63a7  2fc4  0000
ADSP-BF526-0.2 400(MHz CCLK) 100(MHz SCLK) (mpu off)
Linux version 2.6.34.7-ADI-2010R1-svn5314 (mk@PCHe-Ubuntu) (gcc version 4.3.5 (ADI-2010R1-RC4) ) #640 Thu Dec 22 16:10:34 CET 2011
SEQUENCER STATUS:               Not tainted
SEQSTAT: 00002027  IPEND: 8008  IMASK: ffff  SYSCFG: 0006
  EXCAUSE   : 0x27
  physical IVG3 asserted : <0xffa00744> { _trap + 0x0 }
  physical IVG15 asserted : <0xffa00f80> { _evt_system_call + 0x0 }
  logical irq   6 mapped  : <0xffa00380> { _bfin_coretmr_interrupt + 0x0 }
  logical irq  27 mapped  : <0x000b37b8> { _bfin_twi_interrupt_entry + 0x0 }
  logical irq  31 mapped  : <0x0009c9a0> { _bfin_serial_dma_rx_int + 0x0 }
  logical irq  32 mapped  : <0x0009cdd4> { _bfin_serial_dma_tx_int + 0x0 }
  logical irq  35 mapped  : <0x000b0e64> { _bfin_mac_interrupt + 0x0 }
RETE: <0x00000000> /* Maybe null pointer? */
RETN: <0x01827c10> /* kernel dynamic memory (maybe user-space) */
RETX: <0x00000480> /* Maybe fixed code section */
RETS: <0x006829b4> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xb8 }
PC  : <0x006829c0> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xc4 }
DCPLB_FAULT_ADDR: <0x0000000c> /* Maybe null pointer? */
ICPLB_FAULT_ADDR: <0x006829c0> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xc4 }
PROCESSOR STATE:
R0 : 01369603    R1 : 00000003    R2 : 007b4368    R3 : 00000000
R4 : 006a6200    R5 : 000000f8    R6 : 006a6200    R7 : 00000000
P0 : 007b4368    P1 : 00000000    P2 : 007b1dec    P3 : 004680f8
P4 : 007b3408    P5 : 007b4368    FP : 0008d658    SP : 01827b34
LB0: 0008a854    LT0: 0008a852    LC0: 00000000
LB1: 0008d71a    LT1: 0008d70a    LC1: 00000000
B0 : 00000000    L0 : 00000000    M0 : 00000000    I0 : 00468100
B1 : 00000000    L1 : 00000000    M1 : 00000000    I1 : 007b66a4
B2 : 00000000    L2 : 00000000    M2 : 00000000    I2 : 00000000
B3 : 00000000    L3 : 00000000    M3 : 00000000    I3 : 00000000
A0.w: 00006666   A0.x: 00000000   A1.w: 0000234b   A1.x: 00000000
USP : 018e0d10  ASTAT: 02002060
Hardware Trace:
   0 Target : <0x00003ef4> { _trap_c + 0x0 }
     Source : <0xffa006d8> { _exception_to_level5 + 0xa4 } JUMP.L
   1 Target : <0xffa00634> { _exception_to_level5 + 0x0 }
     Source : <0xffa004e8> { _bfin_return_from_exception + 0x18 } RTX
   2 Target : <0xffa004d0> { _bfin_return_from_exception + 0x0 }
     Source : <0xffa0058c> { _ex_trap_c + 0x74 } JUMP.S
   3 Target : <0xffa00518> { _ex_trap_c + 0x0 }
     Source : <0xffa0079e> { _trap + 0x5a } JUMP (P4)
   4 Target : <0xffa00744> { _trap + 0x0 }
      FAULT : <0x006829c0> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xc4 } R2 = W[P1 + 3](X)
     Source : <0x006829be> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xc2 } [P2 + 1] = R0
   5 Target : <0x006829b4> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xb8 }
     Source : <0x00087d1a> { _rb_prev + 0x2a } RTS
   6 Target : <0x00087d18> { _rb_prev + 0x28 }
     Source : <0x00087d30> { _rb_prev + 0x40 } IF CC JUMP pcrel
   7 Target : <0x00087d2a> { _rb_prev + 0x3a }
     Source : <0x00087d24> { _rb_prev + 0x34 } JUMP.S
   8 Target : <0x00087d22> { _rb_prev + 0x32 }
     Source : <0x00087d08> { _rb_prev + 0x18 } IF CC JUMP pcrel
   9 Target : <0x00087cf0> { _rb_prev + 0x0 }
     Source : <0x006829b2> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xb6 } CALL (P2)
  10 Target : <0x006829a8> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xac }
     Source : <0x0068294e> { :jffs2:_jffs2_add_full_dnode_to_inode + 0x52 } IF !CC JUMP pcrel
  11 Target : <0x0068293a> { :jffs2:_jffs2_add_full_dnode_to_inode + 0x3e }
     Source : <0x00682710> { :jffs2:_jffs2_set_inocache_state + 0x170 } RTS
  12 Target : <0x00682700> { :jffs2:_jffs2_set_inocache_state + 0x160 }
     Source : <0x00087cce> { _rb_next + 0x2a } RTS
  13 Target : <0x00087ccc> { _rb_next + 0x28 }
     Source : <0x00087ce4> { _rb_next + 0x40 } IF CC JUMP pcrel
  14 Target : <0x00087cde> { _rb_next + 0x3a }
     Source : <0x00087cd8> { _rb_next + 0x34 } JUMP.S
  15 Target : <0x00087cd6> { _rb_next + 0x32 }
     Source : <0x00087cbc> { _rb_next + 0x18 } IF CC JUMP pcrel
Kernel Stack
Stack info:
SP: [0x01827f24] <0x01827f24> /* kernel dynamic memory (maybe user-space) */
Memory from 0x01827f20 to 01828000
01827f20: 7fffffff [018bd14a] 00008000  00002000  00000000  01828000  018bd14a  018bd14a
01827f40: 018c1f92  ffa00fe4  02001044  018bec35  018bf891  018bec34  018bf88e  00000000
01827f60: 00000000  0000234b  00000000  00006666  00000000  00000000  00000000  00000000
01827f80: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
01827fa0: 00000000  00000000  00000000  00000001  018d4424  018e0d10  018e0d1c  006ca190
01827fc0: 006ca1ac  0000002d  000000f8  018d0edf  00000004  0000000a  0000000a  7fffffff
01827fe0: 00000000  00000003  0000000a  006ca190  00000004  00000004  00000004  00000006
Return addresses in stack:
Modules linked in: jffs2 zlib_deflate
Kernel panic - not syncing: Kernel exception
Hardware Trace:
Stack info:
SP: [0x01827a58] <0x01827a58> /* kernel dynamic memory (maybe user-space) */
FP: (0x01827cb8)
Memory from 0x01827a50 to 01828000
01827a50: 01827a58  00000013 [0012f928] 0010646e  01827b34  0012f928  001604be  001604be
01827a70: 001604be  01827a88  00004330  01827b34  00008008  01827b34  0000003f  0000003f
01827a90: 00000000  00000000  0003000b  00000000  00000000  00020000  00000000  00030005
01827ab0: 00000000  00000000  00000000  00040000  00000000  00000000  00000000  00000000
01827ad0: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
01827af0: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
01827b10: ffa006dc  0015d000  00008008  00002027  000000f8  006a6200  00000000  00000000
01827b30: 00000480  00000480  00008008  00002027  00000000  01827c10  00000480  006829c0
01827b50:<006829b4> 01369603  02002060  0008d71a  0008a854  0008d70a  0008a852  00000000
01827b70: 00000000  0000234b  00000000  00006666  00000000  00000000  00000000  00000000
01827b90: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
01827bb0: 00000000  00000000  00000000  007b66a4  00468100  018e0d10  0008d658  007b4368
01827bd0: 007b3408  004680f8  007b1dec  00000000  007b4368  00000000  006a6200  000000f8
01827bf0: 006a6200  00000000  007b4368  00000003  01369603  01369603  007b4368  00000006
01827c10:<00687366> 007b6660  007a7a8c <006873c4> 007b6660  007a7a8c  007b3408  00000000
01827c30: 00174b0c  01827cb8  004680f8  004680f8  0000000a  00000003  00000000  00000000
01827c50: 000000f8  00000f08  00000000  00000000  0000000a  0000000a  00002a00  004680f8
01827c70: 000000f8 <00681a74> 007b6660  007a7ab4  007f3d00  006a6200  000000f8  000000f8
01827c90: 00000102  00000000  00000000  0000db4a  004680f8  000000f8  0000000a  01827cb4
01827cb0: 00000000  00000000 (00000000)<0003196e> 01826000  001667c0  007a7b4c  0000000a
01827cd0: 0000000a  000000f8  00000f08 <0068df3a> 0004046c  000000f8  00000000  0000000a
01827cf0: 0000000a  007f3d00  006a6000  0068ed90  00000000  00000000  000000f8  006a6000
01827d10: 007f3d00  007a7b4c  00031ab0  01827e54  0104b920  000000f8  01827d4c  00000000
01827d30: 00000000  000000f8  0104b920  01827d4c  000000f8  00000000  0104b920  01827e90
01827d50: 00000001  00000000  0000000a  00033232  007a7ab4  0000000a  01827e90  00000000
01827d70: 00000000  00000241  00000022  01827e90  000000f8  00000000  01827e54  0000000a
01827d90: 00000000  0104b920  0000000a  00000000  000000f8  00000000  45984f02  00000000
01827db0: 0000000a  018e0d1c  0003342c  01827e20  0104b920  00000001  007a7b20  01827e90
01827dd0: 000000f8  00000000  01827e20  01827e90  00000001  01827e54  00000000 <00042e22>
01827df0: 01827e20  0104b920  01827ef0  01827e90  006ca190  0000000a  0000000a  000001b6
01827e10: 0104a000  0000003f  000000f8  00000000  01826000  00000000  00000000  00000001
01827e30: ffffffff  0104b920  00000000  00000000  00000000  00000000  01045920  00000000
01827e50: 00000000  000000f8  00000000  01827db8  0016a588  0000000a  00000802  0000000a
01827e70: 018e0e88  00040aea  00000000  00000002  007a7ab4  0104b920  018e0ce0  00043684
01827e90: 006ca190  0000000a <00043628> 0104b920  00000004  0000002d  01827ef0  0004cf72
01827eb0: 0104b920  00000036  01827ef0  00000000  00000000  0004374c  0104b920  00000004
01827ed0: 006ca190  0000000a  7fffffff  00000000  00000004  00000241  ffffe000  01827ef0
01827ef0: 000000f8  00000000  00000000 <ffa008d6> 0004371c  00000000  ffffe000  ffffe000
01827f10: 000003e0  0000fffe  00000003  00000000  7fffffff  018bd14a  00008000  00002000
01827f30: 00000000  01828000  018bd14a  018bd14a  018c1f92  ffa00fe4  02001044  018bec35
01827f50: 018bf891  018bec34  018bf88e  00000000  00000000  0000234b  00000000  00006666
01827f70: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
01827f90: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000001
01827fb0: 018d4424  018e0d10  018e0d1c  006ca190  006ca1ac  0000002d  000000f8  018d0edf
01827fd0: 00000004  0000000a  0000000a  7fffffff  00000000  00000003  0000000a  006ca190
01827ff0: 00000004  00000004  00000004  00000006
    address : <0x006829b4> { :jffs2:_jffs2_add_full_dnode_to_inode + 0xb8 }
    address : <0x00687366> { :jffs2:_jffs2_write_inode_range + 0x276 }
    address : <0x006873c4> { :jffs2:_jffs2_write_inode_range + 0x2d4 }
    address : <0x00681a74> { :jffs2:_jffs2_compress + 0x1890 }
   frame  1 : <0x0003196e> { _generic_perform_write + 0x9e }
    address : <0x0068df3a> { :jffs2:_jffs2_flash_read + 0xbee }
    address : <0x00042e22> { _do_sync_write + 0x8e }
    address : <0x00043628> { _vfs_write + 0x68 }
    address : <0xffa008d6> { _system_call + 0x6a }
Can you help us?
