AADV7611 HDMI low sharpness problem
Question asked by RAJJAR on Jun 5, 2018
Latest reply on Jun 5, 2018 by PoornimaSubramani
Hi all,
we are using ADV7611 in our product. we dnot have EVM board.
input = 1080p@60
output = 1080p@60 RGB out
Below are my configuration
0x4c 0x15 0xbe   #//Set TRI_AUDIO, TRI_SYNCS, TRI_LLC, TRI_PIX to 1 //stop adv7611
0x4c 0x0B 0x44   #//Powers up CP and digital sections of HDMI block //power up adv7611
0x4c 0x0c 0x42   #//Chip is operational  ////power up adv7611
0x4c 0xF4 0x80   #//CEC
0x4c 0xF5 0x7C   #//INFOFRAME
0x4c 0xF8 0x4C   #//DPLL
0x4c 0xF9 0x64   #//KSV
0x4c 0xFA 0x6C   #//EDID
0x4c 0xFB 0x68   #//HDMI
0x4c 0xFD 0x44   #//CP
0x32 0x77 0x00
0x4c 0x1b 0x01   #//io SAMPLE_ALSB
0x34 0x48 0x40   #//hdmi Do not use the 5 V input pins as reset signal for the HDMI section
0x34 0x15 0xbe   #//hdmi Audio Mute Mask
0x34 0x83 0xff   #//hdmi Disable Termination port A
0x22 0x6c 0x00   #//cp Undocumented register
0x34 0x9b 0x03   #//hdmi Undocumented registe
0x34 0x6f 0x0c   #//hdmi Undocumented registe
0x34 0x85 0x1f   #//hdmi Undocumented registe
0x34 0x87 0x70   #//hdmi Undocumented registe
0x34 0x03 0x98   #//hdmi DIS_I2S_ZERO_CPMPR
0x34 0x4c 0x44   #//hdmi NEW_VS_PARAM
0x22 0x3e 0x00   #//cp Video Adjustment disable
0x22 0x40 0x80   #//cp Default pregain
0x34 0x83 0xfe   #//hdmi Enable Termination port A
0x4c 0x01 0x06   #//io PRIM_MODE
0x4c 0x00 0x02   #//io VID_STD
0x4c 0x0c 0x42   #//io Chip is operational power up adv7611
0x4c 0x14 0x7f   #//io drive strenth
0x4c 0x19 0x83   #//io llc
0x4c 0x33 0x40   #//io Muxes the DLL output on LLC output
0x22 0x69 0x14   #//cp cse enable
0x22 0xBA 0x01
0x4c 0x02 0xf7  #RGB out
0x4c 0x03 0x40  #24-bit
0x4c 0x04 0x62  #VR_YG_UCRCB
0x4c 0x06 0xa1  #Invert clock polarity all negative
0x4c 0x15 0x00
Input image top portion of scan image is perfect curve but output image top curve is not sharp.
Kindly give suggestion for us,
RAJ M
