Question regarding building ADSP-CM40x Enablement Package libraries in IAR EWARM 8.22.2
Question asked by jasonsweng on May 29, 2018
Latest reply on Jun 7, 2018 by PrasanthR
I am trying to take a working IAR EWARM 7.8x project and import and build it in the new IAR EWARM 8.22.2.  Everything imported and built OK, but I am getting a (concerning) IAR warning about inconsistent wchar_t size with the Analog libraries (see link below for more info).
https://www.iar.com/support/tech-notes/general/library-built-with-7.xx--causes-warning-message-in-8.11/
I believe this is because the ADSP-CM40x Enablement Package libraries were built with 7.x version.  However, I get compiler warnings when trying to rebuild the libdrv40z and libssl40z libraries…. And I get compiler errors when I rebuild the libosal40z_noos library.  I’ve included all of the build logs at the bottom of this email.  It looks like the errors just have to do with not being able to find files, but I don’t want to make updates to the project without verification from Analog Devices about the proper way to do this.
Do you have any recommendations on how (or if) we should be using the Analog libraries in IAR EWARM 8.xx???  Note, we are using the latest v2.1.0 ADSP-CM40x Enablement Package libraries and we are using the ADSP-CM408F-A device.  FYI, I did notice on importing the project in EWARM 8.22.2 that the Device (under General Options->Target->Device: AnalogDevices) got changed to the 409 device.  Also, I needed to recheck the “Use CMSIS” libraries (under IAR General Options->Library Configuration) in some cases.
Ideally, I would like an official ADSP-CM40x Enablement Package library version update (new release) that fully supports 8.xx (with updated IAR project files and pre-built library files).  Please let me know if you think this would be possible.
Jason
Example build warning in our application project:
Linking
Warning[Lt009]: Inconsistent wchar_t size
            adi_gpio.o(libssl40z.a) and 10 other objects in 6 different libraries have wchar_t size 16 bits
            adi_initialize.o and 39 other objects, some of them in dl7M_tln.a and 15 other libraries have wchar_t size 32 bits
Total number of errors: 0
Total number of warnings: 1
Building Analog Device Libraries below….
Building configuration: libdrv40z - Release
Updating build tree...
17  file(s) deleted.
adi_counter.c
adi_adcc.c
Warning[Pe177]: variable "eResult" was declared but never referenced C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\adcc\adi_adcc.c 1722
Warning[Ta023]: Call to a non __ramfunc function (adi_osal_EnterCriticalRegion) from within a __ramfunc function C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\adcc\adi_adcc.c 2613
Warning[Ta023]: Call to a non __ramfunc function (adi_osal_ExitCriticalRegion) from within a __ramfunc function C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\adcc\adi_adcc.c 2656
Warning[Ta023]: Call to a non __ramfunc function (adi_osal_EnterCriticalRegion) from within a __ramfunc function C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\adcc\adi_adcc.c 3080
Warning[Ta022]: Possible rom access (<ptr>) from within a __ramfunc function C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\adcc\adi_adcc.c 3109
Warning[Ta023]: Call to a non __ramfunc function (adi_osal_ExitCriticalRegion) from within a __ramfunc function C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\adcc\adi_adcc.c 3121
adi_crc.c
adi_dacc.c
adi_flash.c
Warning[Pe177]: variable "nMaxBlock" was declared but never referenced C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\flash\adi_flash.c 353
Warning[Pe177]: variable "nMaxBlock" was declared but never referenced C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\flash\adi_flash.c 493
Warning[Ta022]: Possible rom access (<ptr>) from within a __ramfunc function C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\flash\adi_flash.c 1142
Warning[Pe177]: function "write_reg" was declared but never referenced C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\flash\adi_flash.c 1667
adi_hae.c
adi_sinc.c
adi_spi_bf6xx.c
adi_sport_bf6xx.c
adi_usbd_dev_bsp_musbmhdrc.c
adi_uart_bf60x.c
adi_twi.c
Warning[Pa082]: undefined behavior: the order of volatile accesses is undefined in this statement C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\twi\adi_twi.c 1063
Warning[Pa082]: undefined behavior: the order of volatile accesses is undefined in this statement C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\twi\adi_twi.c 1069
Warning[Pa082]: undefined behavior: the order of volatile accesses is undefined in this statement C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\drivers\twi\adi_twi.c 1087
adi_usbd_dev_common.c
adi_usbd_dev_musbmhdrc_intrpt.c
adi_usbd_dev_musbmhdrc_state.c
adi_usbd_dev_musbmhdrc.c
Building library
Performing Post-Build Action
Total number of warnings: 13
Building configuration: libssl40z - Release
11  file(s) deleted.
adi_gpio.c
adi_nvic.c
adi_cpt_v1.c
adi_int_nvic.c
adi_dma_bf60x.c
adi_tru.c
adi_pwm_bf6xx.c
adi_tmr_bf6xx.c
adi_pwr_bf60x.c
adi_wd_bf6xx.c
Warning[Pe188]: enumerated type mixed with another type C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\src\services\wd\adi_wd_bf6xx.c 230
Building library
Total number of warnings: 2
Building configuration: libosal40z_noos - Release
0  file(s) deleted.
adi_osal_arch_c.c
Fatal Error[Pe1696]: cannot open source file "osal_common.h" C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\lib\iar\libosal40z_noos\Ports\adi_osal_arch_c.c 26
            searched: "C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\
lib\iar\libosal40z_noos\Ports\"
lib\iar\libosal40z_noos\..\..\..\inc\"
            searched: "..\source\"
            searched: "..\ports\"
            searched: "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\CMSIS\Core\Include\"
            searched: "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\CMSIS\DSP\Include\"
            searched: "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\inc\"
            searched: "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\inc\c\"
            current directory: "C:\Repositories\ADSP-CM40x\
CM403F_CM408F_EZ-KIT\lib\iar"
Error while running C/C++ Compiler
adi_osal_noos_active.c
adi_osal_noos.c
Fatal Error[Pe1696]: cannot open source file "adi_osal_arch_internal.h" C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\lib\iar\libosal40z_noos\Source\osal_noos.h 28
adi_osal_arch_int_table.c
adi_osal_noos_critical.c
adi_osal_noos_event.c
adi_osal_noos_init.c
adi_osal_noos_mutex.c
adi_osal_noos_prof.c
adi_osal_noos_rtl_lock.c
adi_osal_noos_sem.c
adi_osal_noos_thread.c
adi_osal_noos_timing.c
adi_osal_noos_arch_c.c
Fatal Error[Pe1696]: cannot open source file "osal_common.h" C:\Repositories\ADSP-CM40x\CM403F_CM408F_EZ-KIT\lib\iar\libosal40z_noos\Ports\adi_osal_noos_arch_c.c 6
adi_osal_noos_tls.c
Total number of errors: 12
Total number of warnings: 0
