rajesh_573
Cycle Count for SC573-Cortex A5 processor
Discussion created by rajesh_573 on May 28, 2018
Latest reply on May 29, 2018 by daveG
I tried to get the cycle count for ADSP-SC573 -ARM in different ways. But i got  cycle count=0 for every case.  Listing out the different ways i tested for the same.
  1. Using Core Cycle-Counting Macros defined in cycle_count.h
    #include <cycle_count.h>
    #include<stdio.h>
    #include<stdlib.h>
    int main()
    int i;
    cycle_stats_t CyclsTst;
    CYCLES_INIT(CyclsTst);
    CYCLES_START(CyclsTst);
    for (i=0;i<500;i++)
    int c1=1,a=5,c2=2,b=10,sum;
    sum = (c1*a)+(c2*b);
    CYCLES_STOP(CyclsTst);
    printf("\n=========Print cycle count values=========\n");
    CYCLES_PRINT(CyclsTst);
    return 0;
  2. Using A5_PMU source files which is attached in EngineerZone discussion:ADSP-SC58x/2158x PMU Overflow Interrupt- Example code
    #include<stdio.h>
    #include<stdlib.h>
    int main()
    A5_Start_Cycle_Count();
    printf("Read Cycle_Count = %d\n", A5_Read_Cycle_Count());
    int i;
    for (i=0;i<500;i++)
    A5_Stop_Cycle_Count();
    return 0;
  3. Using example code downloaded from ARM community: DS-5 Development Studio | Using the PMU Event Counters in DS-5 – Arm Developer
    #include<stdio.h>
    #include<stdlib.h>
    int main()
    int i;
    start_counters(); //Configure and Start the counters
    for (i=0;i<500;i++)
    stop_counters(); //Stop the counters
    printf("\nPerformance monitor results\n\n");
    printf("Instructions Executed = %u\n", read_pmn(0) );
    printf("Cycle Count (CCNT) = %u\n", read_ccnt() );
    printf("Data Accesses = %u\n", read_pmn(1) );
    printf("Data Reads = %u\n", read_pmn(2) );
    printf("Data Writes = %u\n", read_pmn(3) );
    inst=read_pmn(0);
    cycl=read_ccnt();
    cycl_inst=cycl/inst;
    printf("Average cycles per instruction = %f\n",cycl_inst);
    return 0;
For all the above codes i am getting cycle count as 0. I am using QEMU(Debug Configuration used :- Application with GDB and QEMU(Simulator) ) simulator to view the output.
