BF518 SD Host driver issue
Question asked by thangaraj on Dec 20, 2011
Latest reply on Dec 23, 2011 by vivili
Hi ,
I am working in BF518 ezkit and 2010 kernel.
I tested the SD card with the help of below link
http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:drivers:bfin_sdh#bf51x_sd_mmc_performance
the kerenl message is given below
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SD card at address 0001
mmcblk0: mmc0:0001 128MB 119 MiB
mmcblk0:
to scan the SD card i followed the below information in the above link
"The SDH driver doesn't support automatic card detection currently.  So card scanning must be triggered manually by doing: echo 0 > /proc/driver/sdh"
But i couldnt see the driver sdh under  the /proc/drivers folder.
if i try to mount the sd card by the below commands,the kernel hangs.
mount -t vfat /dev/mmcblk0 /mnt
i got the below error in the u-boot while running in the command mmcinfo
U-Boot 2010.06 (ADI-2010R1-RC2) (Dec 20 2011 - 11:17:53)
CPU:   ADSP bf518-0.0 (Detected Rev: 0.0) (parallel flash boot)
Board: ADI BF518F EZ-Board board
       Support: http://blackfin.uclinux.org/
Clock: VCO: 400 MHz, Core: 400 MHz, System: 80 MHz
RAM:   64 MiB
Flash: 4 MiB
MMC:  Blackfin SDH: 0
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
Net:   bfin_mac
Hit any key to stop autoboot:  0
bfin>
bfin>
bfin> mmcinfo
sending CMD8 failed
tranfering data failed
sending CMD51 failed
Device: Blackfin SDH
Manufacturer ID: 18
OEM: 494e
Tran Speed: 25000000
Rd Block Len: 512
SD version 1.0
High Capacity: No
Capacity: 125698048
Bus Width: 1-bit
bfin>
Please clarify if any mistakes in my test procedure and also suggest what could be reasons for the above issues.
Thank you,
Thangaraj
