ADXL355 measure inclination
Question asked by HOD on May 27, 2018
Latest reply on May 31, 2018 by lallison
Hi
I have a question.
I want to measure inclination using ADXL 355
I would like to tell you if you have knowledge about how to obtain the inclination.
As a reference of the tilt we use the following. (Equation 11.12).
http://www.analog.com/media/jp/technical-documentation/application-notes/AN-1057_en.pdf
【Consultation matter】
If you want to measure the inclination of the two axes, the other axis (Z axis) also changes when the Y axis is inclined.
I'd like to confirm what seems to be the cause of this change.
· When only the Y axis is tilted (In this case, since it rotates around the Z axis, it should be 0 G at any tilt)
The Z axis seems to move, but what is the cause? (Measurement error? Multi-axis sensitivity is on?)
Please tell me if you have any theoretical knowledge.
· Is there a method to suppress errors?
Best Regards
HOD
