modprobe: module ip_tables not found in modules.dep
Question asked by parashuram on Dec 19, 2011
Latest reply on Dec 21, 2011 by parashuram
Hi EZ,
I am trying to run iptable script on uClinux platform on BF537 Stamp board, I 've enabled net filter using 'make menuconfig' command
when i run script it pops with the following error.
SETTING UP IPTABLES PROXY...
Loading required stateful/NAT kernel modules...
sh: can't execute '/sbin/depmod': No such file or directory
modprobe: module ip_conntrack not found in modules.dep
modprobe: module ip_conntrack_ftp not found in modules.dep
modprobe: module ip_conntrack_irc not found in modules.dep
modprobe: module iptable_nat not found in modules.dep
modprobe: module ip_nat_ftp not found in modules.dep
modprobe: module ip_nat_irc not found in modules.dep
    Enabling IP forwarding...
    External interface: eth2
       External interface IP address is: 192.168.4.9
    Loading proxy server rules...
iptables v1.4.5: can't initialize iptables table `nat': Table does not exist (do
you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
iptables: No chain/target/match by that name.
       Proxy server rule loading complete
  Allowing packets with ICMP data (pings)
i think i need to enable some modules but no idea which are those modules i need to enable
any lights on how to solve this error??
