Some problems with the initialization of ADXL372
Question asked by edc on May 20, 2018
Latest reply on May 21, 2018 by jwang
I used the ADXL372 vibration sensor, MPU is stm32L452RE, and I used the No-Os driver of ADXL372 provided by analog(ADXL372 - No-OS Driver [Analog Devices Wiki] ). I have some problems.
1: initialization needs to be written 5 times, otherwise it will not be able to read normally.
2: If it is powered on again, it will enter a hardware interrupt and will not work.
3: Can I use adxl372_get_accel_data () in FULL_BW_MEASUREMENT model and set FIFO in FIFO BYPASSED mode?
//=========================== include =========================================
#include "board.h"
#include "timers.h"
#include "scheduler.h"
#include "applications.h"
#include "vibration.h"
//=========================== main ============================================
int main(void)
   /* Initialize. */
   board_init();
   timers_init();
   scheduler_init();
   adxl372_dev *dev;
   adxl372_init_param param;
   param.spi_init = hspi2.Init;
   param.bw                        = ADXL372_BW_1600HZ;
   param.odr                       = ADXL372_ODR_3200HZ;
   param.op_mode                   = ADXL372_FULL_BW_MEASUREMENT;
   param.fifo_config.fifo_mode     = ADXL372_FIFO_BYPASSED;
   param.fifo_config.fifo_samples  = 0 ;
   adxl372_xyz_accel_data temp[1]={0};
   dev->spi_desc = &hspi2;
   adxl372_init(&dev, param);
   while(1){
   for(int i=0;i<6400;i++){
   adxl372_get_accel_data(dev, temp);
   led_toggle();
   HAL_Delay(1000);
   return 0;
int32_t adxl372_get_accel_data(adxl372_dev *dev,
       adxl372_xyz_accel_data *accel_data)
uint8_t buf[6];
uint8_t status1, status2;
uint16_t fifo_entries;
int32_t ret=0;
do {
adxl372_get_status(dev, &status1, &status2, &fifo_entries);
} while(!(ADXL372_STATUS_1_DATA_RDY(status1)));
ret = adxl372_spi_reg_read_multiple(dev,
    ADXL372_X_DATA_H,
    buf, 6);
if (ret)
return -1;
accel_data->x = (buf[0] << 4) | (buf[1] >> 4);
accel_data->y = (buf[2] << 4) | (buf[3] >> 4);
accel_data->z = (buf[4] << 4) | (buf[5] >> 4);
return ret;
