21489 SPORT in slave receive mode generates interrupt before receiving all the bits.
Question asked by esterling on May 16, 2018
Latest reply on May 25, 2018 by Jithul_Janardhanan
I am using an AD7671 ADC in master serial mode tied to my ADSP-21489 SPORT2. The conversion rate to the ADC is 200KHz. The data that I read from the serial port doesn't seem to be correct, so I added a signal that I toggle when get into the SPORT 2 ISR. The signal is toggling while data is still being shifted in. So it seems that I get an interrupt at the beginning of the serial transfer and not when all the data bits are being received.
I read the serial port, do some processing, and output to another serial port to a DAC in the ISR.
This is the basic scaled down code.
// *********Set up port
// AC A/D SPORT 2 (SLAVE)
SRU(LOW,DAI_PBEN12_I); // SCLK
SRU(LOW,DAI_PBEN13_I); // SYNC
SRU(LOW,DAI_PBEN14_I); // SDOUT
SRU(DAI_PB12_O,SPORT2_CLK_I);
SRU(DAI_PB13_O,SPORT2_FS_I);
SRU(DAI_PB14_O,SPORT2_DA_I);
// *********Set up SPORT
r0 = 0;
dm(SPMCTL2) = r0;
dm(SPCTL2) = r0;
r0 = 8;
dm(DIV2) = r0;
r0 = SPEN_A | SLEN16 | LAFS | FSR | CKRE;
dm(SPCTL2) = r0;
// ***********Enable Interrupts
BIT CLR MODE1 NESTM; // Disable Nested Interrupts
NOP;
NOP;
BIT SET MODE1 CBUFEN; // Enable Circular Buffering
NOP;
NOP;
BIT SET MODE1 IRPTEN; // Enable global interrupts
LIRPTL = SP2IMSK;
NOP;
NOP;
// **************ISR
_sport2_isr:
PUSH STS;
BIT SET MODE1 SRD1L | SRD1H | SRD2L | SRD2H | SRRFL | SRRFH;
NOP; NOP;
SRU(LOW,DPI_PB13_I);
SRU(HIGH,DPI_PB13_I);
r2 = dm(RXSP2A);
r2 = LSHIFT r2 BY -4;
dm(TXSP5A) = r2;
POP STS;
RTI;
_sport2_isr.end:
Of coarse there is another interrupt that is used to convert the ADC. The ADC then sends the serial data when done.
Anyone with some help?
Ed
