ADV7391 SYNC amplitute setting
Question asked by Rani.fe Employee on May 13, 2018
Latest reply on May 14, 2018 by GuenterL
Customer is using the adv7391. The sync amplitude signal does not flow from 0V to 300mV, for SD definition, it has some offset on it, of 40mV. See attached scope screen shot.
My question is if this can be corrected by adjusting the amplitude of the DAC or other.
The configuration of the part is as follows:
WHEN NTSC_INIT =>     -- NTSC
                                                ADDRESS <= i2c_wr_addr;
                                                CASE COUNTER IS
                                                  WHEN 0 =>
                                                  SUBADDRESS <= X"17";
                                                  DATA <= X"00";                       -- NO Soft Reset
                                                  WHEN 1 =>
                                                  SUBADDRESS <= X"00";
                                                  DATA <= X"10";                       -- DAC1 ON, PLL ON
                                                  WHEN 2 =>
                                                  SUBADDRESS <= X"01";
                                                  DATA <= X"00";                       -- Standard Definition Input Mode
                                                  WHEN 3 =>
                                                  SUBADDRESS <= X"02";
                                                  DATA <= X"20";                       -- CVBS output on DAC 1
                                                  WHEN 4 =>
                                                  SUBADDRESS <= X"80";
                                                  DATA <= X"10";                       -- NTSC Mode, luma and chroma filters ON
                                                  WHEN 5 =>
                                                  SUBADDRESS <= X"82";
                                                  DATA <= X"CB";                      -- CVBS output with pedestal enabled
                                                  WHEN 6 =>
                                                  SUBADDRESS <= X"8A";
                                                  DATA <= X"0C";                      -- Slave Mode 2, HSYNC, VSYNC IN , -40 IRE
                                                  WHEN 7 =>
                                                  SUBADDRESS <= X"8C";
                                                  DATA <= X"1F";                         -- Fsc0
                                                  WHEN 8 =>
                                                  SUBADDRESS <= X"8D";
                                                  DATA <= X"7C";                        -- Fsc1
                                                  WHEN 9 =>
                                                  SUBADDRESS <= X"8E";
                                                  DATA <= X"F0";                         -- Fsc2
                                                  WHEN 10 =>
                                                  SUBADDRESS <= X"8F";
                                                  DATA <= X"21";                         -- Fsc3
                                                  WHEN 11 =>
                                                  DAC_state_type <= DO_BIT;
                                                  WHEN OTHERS =>
                                                  null;
                      END CASE;
Rani
