ADG1406 source charge injection
Question asked by carls on May 11, 2018
Latest reply on May 14, 2018 by carls
I would like to use the Multiplexer 'in reverse', charging several S/H capacitors (around 100nF) with one DAC one after another (simplified picture).
I need the low Rds_on, so using ADG12xx is not possible.
I'm missing the source charge injection in the datasheet, effectively figure 33 in the datasheet with source/drain swapped.
Is it in the same range or worse? Are there compensation capacitances?
Are there any numbers available? Best would be at +-15V supply and over the full range (worst case or plot).
Carl
