Where to add custom decimation in FMCDAQ2 Reference Design
Question asked by dfa327 on May 4, 2018
Latest reply on May 21, 2018 by dfa327
Hello
  I have a zc706 and an FMCDAQ2.  I'm using the reference design and everything works great out of the box.  Now I want to reduce the ADC sample rate from 1GSps to 4MSps.  I placed a custom decimation IP block between the axi_ad9680_cpack and axi_ad9680_fifo.  All it does is divide by 250, by counting the adc_clk's before it sets the adc_wr bit high.  I've attached the example reference design minus my custom IP block.
System reference design
Problem is when I include it, it doesn't seem to get me a nice 4Mhz sample frequency.  It appears I've reduced the sample frequency by a lot more then 250.   I read here (How to reduce sample rate to 1Mbps in of the DAQ2 noOS project for the KCU105? ) that I'd need a custom decimation filter, but I'm not sure I'm placing it in the correct place.  I'm assuming the adc_clk is 250Mhz.  Is that a safe assumption?  Should I place my decimate IP someplace else?
Here's where I placed my custom ip I wrote with HLS:
Custom Divider IP Core
Here is the code I wrote in HLS to create my custom divider ip core.
Here's my divider.h file:
#ifndef _DIVIDER_H_
#define _DIVIDER_H_
#include <ap_cint.h>
#include <stdio.h>
typedef volatile bool dinb_t;
typedef volatile uint128 din_t;
typedef volatile bool doutb_t;
typedef volatile bool * doutb_pt;
typedef volatile uint128 dout_t;
typedef volatile uint128 * dout_pt;
void divider(dinb_t in_adc_valid,
        din_t in_adc_data,
        doutb_pt out_adc_valid,
        dout_pt out_adc_data);
#endif
Here's my divider.c file:
#include "divider.h"
uint6 dividerCount = 0;
#define DIVIDER_K 62 //Approximately 4Mhz sample, assuming 4 samples at 250Mhz
        din_t in_adc_data,
#pragma HLS INTERFACE ap_none port=out_adc_data
#pragma HLS INTERFACE ap_ctrl_none port=return
#pragma HLS INTERFACE ap_none port=out_adc_valid
#pragma HLS INTERFACE ap_none port=in_adc_data
#pragma HLS INTERFACE ap_none port=in_adc_valid
#pragma HLS PIPELINE
    dout_t tmp_in_adc_data = in_adc_data;
    *out_adc_valid = false;
    if ( in_adc_valid == true)
        if (++dividerCount == DIVIDER_K)
            dividerCount = 0;
            *out_adc_valid = true;
    *out_adc_data = in_adc_data;
