AD5933 Unexpected Measurements
Question asked by ryan.holman@ucsf.edu on Apr 27, 2018
Latest reply on Apr 30, 2018 by Snorlax
Why am I getting a signal shift when performing a frequency sweep of a 22 kOhm resistor.  Below are plots for the real component and the imaginary component.
The real component should theoretically be constant, so I would expect the real component to also be constant.   Also the shifts occur at different frequencies for the real and imaginary components, so it does not appear to be an external signal causing this.
I performed a second scan and the real and imaginary readings were essentially identical.  Using the magnitude at each frequency point to calibrate the resistor resulted in the following graph.
.PNG
How do I generate a constant or linear real component reading when performing a frequency sweep of only a resistor?
