ADP5080 I2C Timing
Question asked by Yuya on Apr 25, 2018
Latest reply on May 6, 2018 by Yuya
My customer is considering using ADP 5080 and received a question.
REG 2 is used for VDDIO and another DCDC regulator is used for I2C pull-up.
When the EN pin was set to H, the power supply sequence did not start and was not output.
# 1   I referred to "If VDDIO is supplied by VREG2, SCL must be high impedance until VREG2 rises above the POR
        threshold." described in the data sheet.
        How can I make SCL high impedance?
        Should I pull up SCL to H?
#2    Is there a sequence diagram showing the timing of VDDIO and I2C startup?
Best Regards,
Yuya
