make -C projects/adv7511/zc706/ failed
Question asked by MengLi on Apr 24, 2018
Latest reply on Apr 24, 2018 by AdrianC
I use Vivado_2017.4 and the branch hdl_2018_r1 of HDL project. I can build zc702 successfully, but zc706 failed.
error log as below:
wrsadmin@pek-mli1-d2:~/Project/extend_disk1/sdk-xilink/adi/hdl$ make -C projects/adv7511/zc706/
make: Entering directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/projects/adv7511/zc706'
make[1]: Entering directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library/axi_clkgen'
make[1]: Leaving directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library/axi_clkgen'
make[1]: Entering directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library/axi_hdmi_tx'
make[1]: Leaving directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library/axi_hdmi_tx'
make[1]: Entering directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library/axi_spdif_tx'
make[1]: Leaving directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library/axi_spdif_tx'
Building adv7511_zc706 project [/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/projects/adv7511/zc706/adv7511_zc706_vivado.log] ... FAILED
For details see /home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/projects/adv7511/zc706/adv7511_zc706_vivado.log
../../scripts/project-xilinx.mk:53: recipe for target 'adv7511_zc706.sdk/system_top.hdf' failed
make: *** [adv7511_zc706.sdk/system_top.hdf] Error 1
make: Leaving directory '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/projects/adv7511/zc706'
log in adv7511_zc706_vivado.log
source system_top.tcl -notrace
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/wrsadmin/Project/extend_disk1/sdk-xilink/adi/hdl/library'.
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/home/wrsadmin/Project/extend_disk1/sdk-xilink/Vivado/Vivado/2017.4/data/ip'.
Command: synth_design -top system_top -part xc7z045ffg900-2
Starting synth_design
Attempting to get a license for feature 'Synthesis' and/or device 'xc7z045'
WARNING: [Common 17-348] Failed to get the license for feature 'Synthesis' and/or device 'xc7z045'. Explanation: The license feature Synthesis could not be found.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
3 Infos, 1 Warnings, 0 Critical Warnings and 1 Errors encountered.
synth_design failed
ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z045'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". If you are using a license server, verify that the license server is up and running a version of the xilinx daemon that is compatible with the version of Xilinx software that you are using. Please note that Vivado 2017.3 and later requires upgrading your license server tools to the Flex 11.14.1 tools. Please confirm with your license admin that the correct version of the license server tools are installed.
INFO: [Common 17-206] Exiting Vivado at Tue Apr 24 17:46:54 2018...
[Tue Apr 24 17:46:54 2018] synth_1 finished
wait_on_run: Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1690.992 ; gain = 0.000 ; free physical = 2110 ; free virtual = 23913
ERROR: [Common 17-69] Command failed: Run 'synth_1' failed. Unable to open
