Issue reading data from X, Y and Z buffers on ADIS16223
Question asked by dstochel on Apr 19, 2018
Latest reply on Apr 26, 2018 by NevadaMark
I'm using an ADIS16223. My code to read the X, Y and Z buffers is just returning 0xFF for each byte, but all other reads and writes seem to be working. Any idea why I am having trouble getting acceleration data from the X, Y and Z buffers?
Here is my code:
// Title: Vibration_Sensor_Tests
// Purpose: A short description of the application.
// Created on: 8/14/2017 at 9:50:56 AM by Physio-Control User.
// Copyright: Physio-Control. All Rights Reserved.
// Include files
#include <analysis.h>
#include "ni845x.h"
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "Vibration_Sensor_Tests.h"
#include "toolbox.h"
// Constants
// Types
// Static global variables
static int panelHandle = 0;
static double bitWeight = 0.004768; //According to the datasheet, conversion factor is 4.768 mg/LSB
static int numberOfSamples = 255;
// Static functions
// Global variables
// Global functions
/// HIFN The main entry-point function.
int main (int argc, char *argv[])
int error = 0;
/* initialize and load resources */
nullChk (InitCVIRTE (0, argv, 0));
errChk (panelHandle = LoadPanel (0, "Vibration_Sensor_Tests.uir", PANEL));
/* display the panel and run the user interface */
errChk (DisplayPanel (panelHandle));
errChk (RunUserInterface ());
Error:
/* clean up */
if (panelHandle > 0)
DiscardPanel (panelHandle);
return 0;
// UI callback function prototypes
/// HIFN Exit when the user dismisses the panel.
int CVICALLBACK panelCB (int panel, int event, void *callbackData, int eventData1, int eventData2)
if (event == EVENT_CLOSE)
QuitUserInterface (0);
return 0;
int CVICALLBACK QuitCallback (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
break;
return 0;
int CVICALLBACK INIT_SPI_COMM (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
uInt8 ReadData[4] = {0, 0, 0, 0};
uInt32 ReadSize = 0;
uInt8 pWriteData[4];
NiHandle DeviceHandle;
NiHandle configHandle;
uInt8 ProdIDAddress = 0x56;
int32 status = 0;
int ProductIdentifier = 0;
//status = ni845xOpen("USB0::0x3923::0x7166::01C57A4F::RAW", &DeviceHandle);
status = ni845xOpen("USB0::0x3923::0x7166::01CB2A51::RAW", &DeviceHandle);
if (status != 0) {
printf("Error Initializing NI USB-8451 Device.\nCheck to ensure that the device is plugged in.\n");
return 0;
status |= ni845xSpiConfigurationOpen(&configHandle);
status |= ni845xSpiConfigurationSetChipSelect (configHandle, 0);
status |= ni845xSpiConfigurationSetClockRate (configHandle, 1000); //1000 The maximum SCLK frequency is 2.25 MHz. Supported clock rates:25 kHz, 32 kHz, 40 kHz, 50 kHz, 80 kz, 100 kHz, 125 kHz, 160 kHz, 200 kHz, 250 kHz, 400 kHz, 500 kHz, 625 kHz, 800 kHz, 1 MHz, 1.25 MHz, 2.5 MHz
status |= ni845xSpiConfigurationSetClockPolarity (configHandle, kNi845xSpiClockPolarityIdleHigh);
status |= ni845xSpiConfigurationSetClockPhase (configHandle, kNi845xSpiClockPhaseSecondEdge);
status |= ni845xSpiConfigurationSetNumBitsPerSample (configHandle, 16);
status |= ni845xSpiConfigurationSetPort (configHandle, 0);
if (status != 0) {
printf("Issue configuring SPI port.");
return 0;
pWriteData[0] = ProdIDAddress; //0x56
pWriteData[1] = 0x00;
pWriteData[2] = 0x00;
pWriteData[3] = 0x00;
status |= ni845xSpiWriteRead (DeviceHandle, configHandle, 4, pWriteData, &ReadSize, ReadData);
if (status != 0 || ReadSize != 4) {
printf("Issue sending the command to get Product Identifier.\n");
return 0;
} else {
ProductIdentifier = (ReadData[2] << 8) | ReadData[3];
printf("Product Identifier Value = %d\n", ProductIdentifier);
if (ProductIdentifier == 16223) { //0x3F5F in hex Note that 65535 is FFFF in hex and is incorrect
printf("The Product Identifier is Correct. \nADIS16223 Vibration Sensor is Connected!\n\n");
} else {
printf("The Product Identifier is Incorrect. ADIS16223 Vibration Sensor is Not Connected!\n\n");
ni845xSpiConfigurationClose(configHandle);
status = ni845xClose(DeviceHandle);
break;
return 0;
int CVICALLBACK GET_VIB_DATA (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
DeleteGraphPlot (panelHandle, PANEL_ACCEL_DATA, -1, 1);
DeleteGraphPlot (panelHandle, PANEL_FFT_DATA, -1, 1);
uInt8 CAPT_BUFFX_Address = 0x14;
uInt8 CAPT_BUFFY_Address = 0x16;
uInt8 CAPT_BUFFZ_Address = 0x18;
uInt8 CAPT_PNTR_Address = 0x9A; //address is actually 0x1A but to write to it, send 9A
uInt8 CAPT_CTRL_Address = 0x9C; //address is actually 0x1C but to write to it, send 9C
uInt8 GLOB_CMD_Address = 0xBE; //address is actually 0x3E but to write to it, send BE
uInt8 AVG_CNT_Address = 0x38;
uInt8 DIAG_STAT_Address = 0x3C;
uInt8 startCapture1 = 0xBF;
uInt8 startCapture2 = 0x08;
int32 status = 0;
//int i = 0;
uInt8 i = 0;
uint16_t tempPeakXValue = 0;
uint16_t tempPeakYValue = 0;
uint16_t tempPeakZValue = 0;
int tempDiagValue = 0;
int16 PeakXValue = 0;
int16 PeakYValue = 0;
int16 PeakZValue = 0;
double PeakXAcceleration = 0;
double PeakYAcceleration = 0;
double PeakZAcceleration = 0;
double PeakXAccelArray[1024];
double PeakYAccelArray[1024];
double PeakZAccelArray[1024];
double timeValues[1024];
if (status != 0) {
return 0;
status |= ni845xSpiConfigurationSetClockRate (configHandle, 1000); //The maximum SCLK frequency is 2.25 MHz. Supported clock rates:25 kHz, 32 kHz, 40 kHz, 50 kHz, 80 kz, 100 kHz, 125 kHz, 160 kHz, 200 kHz, 250 kHz, 400 kHz, 500 kHz, 625 kHz, 800 kHz, 1 MHz, 1.25 MHz, 2.5 MHz
if (status != 0) {
return 0;
//Set Sampling Frequency
pWriteData[0] = AVG_CNT_Address;
pWriteData[3] = 0x00; //Set low-pass and band-pass filter fsc to 72.9 kHz
double Fsc = 72.9E3;
if (status == 0) {
printf("Set sampling frequency to 72.9 kHz.\n\n");
} else {
printf("Error setting the AVG_CNT register!\n");
return 0;
//Turn on Band-Pass Filter and Set Capture Mode to Manual
pWriteData[0] = CAPT_CTRL_Address;
//pWriteData[2] = 0x00;
//pWriteData[3] = 0x80; //Turn on band-pass filter, set capture mode to manual
pWriteData[2] = 0x9C;
if (status == 0) {
printf("Turned on band-pass filter and set capture mode to manual.\n\n");
} else {
printf("Error setting the CAPT_CTRL register!\n");
return 0;
//Start Capture
pWriteData[0] = GLOB_CMD_Address; //0xBE
pWriteData[2] = startCapture1; //0xBF
pWriteData[3] = startCapture2; //0x08
if (status == 0) {
printf("Sent start capture command.\n\n");
} else {
printf("Error sending the start capture command!");
return 0;
//Wait for data to be collected
Delay(0.5);
//Read Diagnostics Register
pWriteData[0] = DIAG_STAT_Address; //0x3C
printf("Issue sending the command to get diagnostics!\n");
return 0;
} else {
tempDiagValue = (ReadData[2] << 8) | ReadData[3];
printf("Daignostics Value = %d\n", tempDiagValue);
if (tempDiagValue == 128) { //0x0080 in hex, means data is ready and the capture is complete
printf("The Diagnostics Value is Correct!\n\n");
} else {
printf("The Diagnostics Value is Incorrect!\n\n");
//At this point, all of the data should be stored in the capture buffer registers.
//Initialize Pointer to Start at 0
pWriteData[0] = CAPT_PNTR_Address; //0x9A
pWriteData[2] = 0x9B;
if (ReadSize == 4 && status == 0) {
printf("Pass\n");
} else {
printf("Fail\n");
i = 0x00;
//Collect X Data
for (i = 0 ; i < numberOfSamples ; i++) {
//Create array of time values
timeValues[i] = i * (1/Fsc); //create time buffer for graphing
pWriteData[0] = CAPT_BUFFX_Address; //0x14
tempPeakXValue = (ReadData[2] << 8) | ReadData[3];
PeakXValue = -1*((~tempPeakXValue)+1);
PeakXAcceleration = (double) PeakXValue * bitWeight;
//printf("Read Data 2: %d\n", ReadData[2]);
//printf("Read Data 3: %d\n", ReadData[3]);
//printf("TEMP PEAK X AXIS Data: 0x%.4x\n", tempPeakXValue);
//printf("PEAK X AXIS Data: 0x%.4x\n", PeakXValue);
//printf("X Value = %u\n", PeakXValue);
//printf("Top X-AXIS Acceleration Point %d: %f g\n\n", i, PeakXAcceleration);
PeakXAccelArray[i] = PeakXAcceleration;
//printf("Status: %d\nRead Size: %d\nX i: %d\n", status, ReadSize, i);
//pWriteData[3] = i;
printf("Pass\n");
i = 0x00;
//Collect Y Data
pWriteData[0] = CAPT_BUFFY_Address; //0x16
tempPeakYValue = (ReadData[2] << 8) | ReadData[3];
PeakYValue = -1*((~tempPeakYValue)+1);
PeakYAcceleration = (double) PeakYValue * bitWeight;
//printf("TEMP PEAK Y AXIS Data: 0x%.4x\n", tempPeakYValue);
//printf("PEAK Y AXIS Data: 0x%.4x\n", PeakYValue);
//printf("Y Value = %u\n", PeakYValue);
printf("Top Y-AXIS Acceleration Point %d: %f g\n\n", i, PeakYAcceleration);
PeakYAccelArray[i] = PeakYAcceleration;
//printf("Y i: %d\n",i);
printf("Pass\n");
i = 0x00;
//Collect Z Data
pWriteData[0] = CAPT_BUFFZ_Address; //0x18
tempPeakZValue = (ReadData[2] << 8) | ReadData[3];
PeakZValue = -1*((~tempPeakZValue)+1);
PeakZAcceleration = (double) PeakZValue * bitWeight;
//printf("TEMP PEAK Z AXIS Data: 0x%.4x\n", tempPeakZValue);
//printf("PEAK Z AXIS Data: 0x%.4x\n", PeakZValue);
//printf("Z Value = %u\n", PeakZValue);
printf("Top Z-AXIS Acceleration Point %d: %f g\n\n", i, PeakZAcceleration);
PeakZAccelArray[i] = PeakZAcceleration;
//printf("Z i: %d\n",i);
PlotXY (panelHandle, PANEL_ACCEL_DATA, timeValues, PeakXAccelArray, i, VAL_DOUBLE, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
PlotXY (panelHandle, PANEL_ACCEL_DATA, timeValues, PeakYAccelArray, i, VAL_DOUBLE, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_BLUE);
PlotXY (panelHandle, PANEL_ACCEL_DATA, timeValues, PeakZAccelArray, i, VAL_DOUBLE, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_GREEN);
break;
return 0;
int CVICALLBACK TimerFunction (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_TIMER_TICK:
double Freq, Amp;
GetGraphCursor (panel, PANEL_FFT_DATA, 1, &Freq, &Amp);
//PowerFrequencyEstimate (Auto_Spec, numberOfSamples/2, 300, WinConst, df, 7, &Freq_Peak, &Power_Peak);
SetCtrlVal(panel, PANEL_FREQ, Freq);
SetCtrlVal(panel, PANEL_AMPL, Amp);
break;
return 0;
